Do you have the schematics on both engine wire harnesses where they connect into the relay center? That's likely most of the problem. 3.1 probably put a pin in a different place.
Also...if you put an HD diff into a non hd w body trans, the gear ratio is going to be 3.29 instead of 2.93. That might piss off the pcm and cause cruise and abs to not work.
So if i put the std diff back in the pcm will not throw the code for incorrect gear ratio, otherwise i would need to swap the gears a chain behind the valve body?
Also not having any luck finding schematics for between relay center and firewall.
