Thread: New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
Results 41 to 60 of 79
Threaded View
  1. #1 New Updates! After swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    SE Level Member JimSWylie's Avatar
    May 2013
    Newport, WA
    NEED HELP! A few problems to work out after swapping 98 gp gtp 3.8 s.c. into a 2002 gp se car
    Not sure if i want to ever do a swap like this again
    1 - The only dtc code ive got is p1651-ran control 1 relay or qdm "B" fault
    fan one does not come on but it did when the 3.1 engine was in the car
    2 - performance shift works but neither indicators show up
    3 - weird one here - low engine oil light is on in all range selections except drive (4rth)
    4 - low coolant level light is on with coolant level good - this also worked correctly when the 3.1 was in the car
    5 - cruise control also does not work and it worked when the 3.1 was in the car
    Do i need to swap the gauge cluster and bcm and or anything else?
    5 - abs not working and it also worked when the 3.1 was in the car
    6 - gear selector indicator in dash cluster not working
    the doner car is a 1998 gp gtp complete car 3.8 s.c.
    the car it went in - 2002 gp s.e with a 3.1
    During the swap installed the engine with pcm and engine wiring harness, picked up a 4t65e trans and put hd my diff into it, swapped the the fuel tank and pump and evap system
    anyone that could chime in on this one would be awesome
  1. 2007 GXP No gears work and reverse lights dont work
    By MikeJenkins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2012, 06:05 AM
  2. Electrical issues on 98 gtp, Half electronics work most dont work
    By Eric Krawczak in forum General Tech Discussion
    Last Post: 04-30-2012, 10:06 AM
  3. Work Gripes About My First World Problems
    By SlowNA06 in forum The Rant Forum
    Last Post: 02-06-2012, 01:04 PM
  4. Will a 98 Key Fob work on a 2002
    By timboku in forum General Tech Discussion
    Last Post: 05-13-2010, 01:36 PM
  5. 2002 GTP Rear Defroster Problems
    By irex511 in forum General Tech Discussion
    Last Post: 01-21-2010, 05:54 PM
