Thread: Worst Intake Gasket Failure Ever
Results 1 to 20 of 31
  1. #1 Worst Intake Gasket Failure Ever
    I live here. TLSheff's Avatar
    I bought 2003 Bonneville SSEi (supercharged 3800) from a kid that said he had been adding coolant for the last 5 months. He said it was leaking coolant and oil and he could only drive 5 miles before it would stall out. He said he was adding 1 gallon of coolant per week.
    draining the oil, which is probably more coolant than oil
    removed the filter
    It took about 30 minutes to drain all that crap out. It was some nasty stuff. I think I drained about 3-4 gallons from the engine. Now with the dis-assembly.
    Since the engine wasn't knocking yet, I decided I was going to try to save it and replace the intake gaskets. The first thing that comes off is the intake tube, and this the first thing I saw. Yes you are seeing that correctly, the "oil" level was all the way up into the supercharger and throttle body.
    leaking all the way into airbox
    Here is the supercharger filled with the oil/coolant solution.
    lifter valley was nasty
    bottom of the lower intake
    I was surprised to see the actual gasket failure wasn't even that bad compared to what I'm used to seeing.
    inside the valve covers
    rockers, what a mess....
    As this point, I’m wondering how in the world I’m going to clean this engine out. It was still running fine and it has a chance to be saved. I did some reading online about how to clean it out, but this was a pretty severe case. I did the unthinkable and took a pressure washer to the lifter valley and the heads. It cleaned up pretty nice. So after washing it out, I poured a gallon of oil all over the top of the engine to help flush any water out. I put the engine back together with new metal intake gaskets and metal coolant elbows. It fired right up and ran great. I did the first oil change after 5 minutes of running. The coolant looked the same as it did the first time from all the crap still in the oil pan. I did another oil change this time with 4 quarts oil and 1 quart of transmission fluid. I ran that mix for about 5 minutes and then drained again. This mix looked more like oil, but still not perfect. I did another oil change with oil and trans fluid and ran it for about 20 minutes. After this change, the oil looked like oil again with a slightly pink tint. I filled up the engine with its most current oil and it’s doing just great. I've logged over 1300 miles on the car since. I think I got pretty lucky.
    __________________________________________________
    Was posted on the GTP Facebook Group but for those that didn't see it.
    (Source) http://imgur.com/a/05azs
  2. #2 Re: Worst Intake Gasket Failure Ever
    holy **** that's awesome lol
  3. #3 Re: Worst Intake Gasket Failure Ever
    I think the reason it came out the intake is because it foamed up so bad, but thats minor compared to what was going on LOL.
    Crazy to see those pictures, glad its running great now.
  4. #4 Re: Worst Intake Gasket Failure Ever
    GTP Level Member
    Pittsburgh
    2003 SSEi,
  5. #5 Re: Worst Intake Gasket Failure Ever
    Mar 2013
    Spring, TX
    Awesome isn't the word I'd use.. haha. That is pretty crazy though.. Good luck with it.
  6. #6 Re: Worst Intake Gasket Failure Ever
    Florida
    That's where all the cookies have gone, into the new SSEI and Creme!
  7. #7 Re: Worst Intake Gasket Failure Ever
    Nov 2011
    Omaha, NE
    If I would have opened it up and seen that I probably would have just sat down and cried. lol
  8. #8 Re: Worst Intake Gasket Failure Ever
    St. Louis
    I honestly can't see how it didn't spin every bearing in the motor, I really can't. I hope it holds together for you. Looks like a nice Bonnie other than the front end.
  9. #9 Re: Worst Intake Gasket Failure Ever
    that engine is so lucky to be alive. amazing.
    i guess you got it for super cheap? car looks pretty damn good. other then the bad lim gaskets.
  10. #10 Re: Worst Intake Gasket Failure Ever
    Feb 2013
    37.295091, -121.930053
    TLSheff is the luckest man in the world right now. and here i thought mine was bad lol you had to go and beat me hahaha
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: Worst Intake Gasket Failure Ever
    No way in hell id keep that engine after all the coolant in it. If its still running its just a matter or time..........
    Amazing what stupid people can do to engines though!!!!
  12. #12 Re: Worst Intake Gasket Failure Ever
    Aug 2013
    McDonald PA
    Your so lucky
  13. #13 Re: Worst Intake Gasket Failure Ever
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    That is awesome man! Congrats
    2001 sliver gtp her name is Reagan
  14. #14 Re: Worst Intake Gasket Failure Ever
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Awesome!
    Go trade it in before it blows!
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  15. #15 Re: Worst Intake Gasket Failure Ever
    The OP TLsheff didnt buy it, he's just posting the pictures and stuff in a thread.
    Read the link posted in post #4.
  16. #16 Re: Worst Intake Gasket Failure Ever
    HUDSON
    I did a head gasket on a 76 Buick 350 that had oil like a vanilla milkshake, after having to pull the motor to get to the head bolts in the rear of the engine, and reassembling everything back correct, the darn thing ran 3 more years I know of in high school, and who knows how long after.
  17. #17 Re: Worst Intake Gasket Failure Ever
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    That's crazy that thing doesn't have a knock.
    I went NA when a whore left -$300 in my bank account.
  18. #18 Re: Worst Intake Gasket Failure Ever
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Not sure if I'm suprised more by that coolant or by how many people fail at reading...LOL!
  19. #19 Re: Worst Intake Gasket Failure Ever
    HAHA Yeah, definitely not mine. Altho, if I could get one on the cheap like that and it still runs, I would buy it and restore it like this and see how long it lasted before throwing in a junkyard motor lol.
    I just came across it on the FB Group and thought I would share for all the L67 lovers out there. I mean I had a small gasket failure, didn't even make the motor act up, but I replaced the factory gaskets anyways at 74k like a good owner, and changed the oil and kept an eye on the motor and everything was fine, but still spun a bearing at 83k. Maybe this one will hold together for him, but I wouldn't be surprised if he has problems down the road. I couldn't find the origin thread, but figured someone would know whose it was.
    Post# 4, good job man, giggled my way through that thread.
  20. #20 Re: Worst Intake Gasket Failure Ever
    Nov 2011
    NY
    That's just sickening! Crazy that it runs afterward, but could be be of those 1 - 1,000,000 that you just can't kill!
    lol
  1. LIM-FelPro gasket failure?
    By michael redmon in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-10-2015, 05:11 AM
  2. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. Worst thing you ever pulled out of air intake?
    By dsmuts in forum Off Topic Discussion
    Last Post: 09-08-2011, 02:33 PM
  5. TB Gasket Failure?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 05:49 PM
