Thread: LIM-FelPro gasket failure?
Results 1 to 14 of 14
  1. #1 LIM-FelPro gasket failure?
    canal winchester, ohio
    Have any of you guys ever heard of a LIM on a 3.1 failing again, even though it was fixed with a FelPro gasket. I had the new gasket put in around 30K miles ago and assumed it would last forever.
  2. #2 Re: LIM-FelPro gasket failure?
    Charles City, IA
    All gaskets will fail sometime. Could have been installed wrong, or been a bad gasket.
    SMGPFC Two Nipple General
  3. #3 Re: LIM-FelPro gasket failure?
    I live here. UR LOSN's Avatar
    Rockford, IL
    number 1 problem besides head gaskets around 150k.........
    LIM gaskets go bout every 80k on a 3.1 and 3.4 depending on driving habits.
  4. #4 Re: LIM-FelPro gasket failure?
    The felpro ones are plastic-y crap...not shocked.
    Get GM aluminum ones.
  5. #5 Re: LIM-FelPro gasket failure?
    HUDSON
    If it fails, you have to look at what made it fail, not just automaticly blame the gasket. Because if you dont find the REAL problem, it will never be fixed.
    If the FEL-PRO re-design is used, and installed properly, there should not be a problem.
  6. #6 Re: LIM-FelPro gasket failure?
    St. Louis Mo.
    Moved to the correct section. And yes I agree, get the aluminum ones if you want something that is gonna last.
    James Shafer
    St. Louis MO
  7. #7 Re: LIM-FelPro gasket failure?
    Bastard Reptile's Avatar
    Kansas City, MO
    As far as I know, I don't think they make aluminum ones for the 3.1. The whole LIM gasket design is bad all around on those engines.
  8. #8 Re: LIM-FelPro gasket failure?
    Thanks guys for all the advice.
    I have coolant in my oil but I was confused because it didnt appear from the signs to be a head gasket but I assumed this Fel-pro gasket was bullet-proof so I kept thinking it HAD to be the head gasket. I will change out the LIM and hopefully that's it (I will know when I get in there!)
  9. #9 Re: LIM-FelPro gasket failure?
    I ending up putting in liquid glass in the my car and it has run perfectly for well over 14 months and 8K miles so far. I dont drive more than 2 hours away from home and check the oil/coolant more than most but so far, so good. Beats changing out a head gasket or intake gasket again. Cost me $40 and a little bit of time + new coolant.
  10. #10 Re: LIM-FelPro gasket failure?
    Just wanted to let you guys know my Grand Prix is still running strong. The product I used was K&W Nano Tech head gasket repair, in a light green bottle. Amazing I have had no problems in 2.5 years and 13K miles! I just followed the directions on the bottle to the tee (draining coolant system and getting it totally clean) I also removed the Thermostat which was the hardest part of the job (couldnt get it out for darn reason!)
    Anyways I hope this helps someone because I have gotten so much good information on this site, thanks!
  11. #11 Re: LIM-FelPro gasket failure?
    Followup: car still running. Around February my thermostat plugged up, I checked the coolant and there appeared to be some engine oil in it. I drained everything, changed that freaking thermostat (a real pain in the rear). Been checking it but nothing leaking between oil and coolant. I go a really long time between oil changes because I put synthetic oil in and only drive 5K a year. I am guessing small amounts of oil is still getting in my coolant but considering it isnt much then I would still suggest this hillbilly fix before spending any real money.
  12. #12 Re: LIM-FelPro gasket failure?
    New York
    Quote Originally Posted by UR LOSN View Post
    Head Gasket can go on the 3.1, 3.4 AND 3.8 at various mileage on the motor. I know of 3.1's with 300,000 miles on the engine with OEM GM head gaskets-never changed. My 3.1 has 170,000 miles on the OEM GM head gaskets…been using Green coolant since 60,000 miles.
    Replaced a head gasket on a 2001 LeSabre with 70,000 miles on the 3.8 motor.
  13. #13 Re: LIM-FelPro gasket failure?
    May 2012
    Where winter never ends
    Head Gaskets rarely go on the 3.8s.... Can happen but rare. 3.1 and 3.4 its as common as dirt
    2000 Regal - Winter Beater
  14. #14 Re: LIM-FelPro gasket failure?
    New York
    Here is one source of many:
    http://www.underhoodservice.com/serv...00-v6-engines/
    "Service IssuesOne of the reasons why the 3800 has had such a long production run is that it has been a very reliable, trouble-free engine for the most part. Many of these engines have racked up well over 200,000 miles with normal maintenance.
    One of the few trouble spots has been coolant leaks on the Series II 3800 engines with the plastic intake manifold. The OEM intake manifold gasket tends to deteriorate after 60,000 or so miles in the area that seals the cylinder head coolant passage to the manifold. The seepage of coolant past the leaky gasket leads to overheating, and may cause bearing damage if coolant leaks down into the lifter valley and gets into the crankcase. The fix is to replace the OEM gasket with an improved aftermarket gasket, or the revised OEM gasket (P/N 89017554) per GM bulletin 04-06-01-017 issued in May, 2004.
    The coolant leakage problem has been blamed on a number of factors, including coolant neglect and a less-than-robust OEM intake manifold gasket design. Though Dex-Cool is supposed to last up to five years or 150,000 miles, some say changing the coolant every two years can avert many of the problems that occur with aging coolant. Also, if the coolant level gets low, oxygen mixes with the coolant, which tends to cause problems with Dex-Cool.
    On these engines, it’s not a bad idea to add a bottle of cooling system sealer to the cooling system for preventive maintenance, whether the coolant needs changing or not. The sealer will circulate with the coolant and hopefully stop any small seepage leaks in the intake manifold gasket from getting any worse, at least for a while. This may save your customer the expense of having to replace the intake manifold gasket. If the gasket is already leaking, sealer may plug it up temporarily. But, eventually, the gasket will have to be changed."
    Not sure where this myth that the head gasket issue does not effect the 3.8 much….
    The GM line of V6's are all great engines and the head gasket issue effects all V6's with the original OEM designed head gaskets. I would guess that my 2001 3.1 with 170,000 miles on the original head gasket is because I switched the Dexcool out at 60,000 miles to Green coolant…..See above for documentation….
  1. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
  2. head light failure
    By kamikaze275 in forum General Tech Discussion
    Last Post: 01-25-2009, 03:46 AM
  3. possible failure yet again??
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-24-2008, 08:40 PM
  4. Clearcoat Failure
    By Warhellride in forum Visual/Body Modifications
    Last Post: 03-05-2008, 09:55 AM
  5. felpro-premiums valve stem seals?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 01:01 PM
