Thread: Thinkin about a 165 degree thermostat
Results 1 to 14 of 14
  1. #1 Thinkin about a 165 degree thermostat
    May 2013
    Hortonville, WI
    I am thinkin about putting a 165 thermo in my 04 gtp comp g. Wondering if that's a good idea or not. Just seems as though when I open my hood after driving its so dam hot in there, cant even touch anything. So thought maybe help it out a little and run it cooler. Is this a good idea or not?
  2. #2 Re: Thinkin about a 165 degree thermostat
    Feb 2013
    37.295091, -121.930053
    its a great idea BUT you need to tell your PCM what the hell is going on.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Thinkin about a 165 degree thermostat
    new britain, ct
    its too cold for no reason.
    if you wanna get a colder t stat, get a 180.
    just an FYI. your engine gets so hot because of the supercharger. even with a thermostat, your supercharger will still throw off a decent amount of heat.
    07 Black GXP.
  4. #4 Re: Thinkin about a 165 degree thermostat
    Feb 2013
    thought compressed air was colder?
  5. #5 Re: Thinkin about a 165 degree thermostat
    Howell, NJ
    nope...
  6. #6 Re: Thinkin about a 165 degree thermostat
    gardner,mass
    what causes a car to run?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  7. #7 Re: Thinkin about a 165 degree thermostat
    Feb 2013
    Quote Originally Posted by Ginseng View Post
    your farts? Kidding
  8. #8 Re: Thinkin about a 165 degree thermostat
    The Boss Iceman6669's Avatar
    Jun 2011
    Running ANY cooler of a tstat is useless without a tune to adjust fans. FWIW I run a 180* with a tune and my junk is still super hot after driving it. Welcome to the world of a blower car.
    2011 F-150 Yote powered
  9. #9 Re: Thinkin about a 165 degree thermostat
    May 2013
    Hortonville, WI
    Ya I have a reprogrammed pcm on its way to me supposed to get it wed. But not sure if its adjusted to that or not. I think that it turns the fans on very slightly earlier, and keeps them runnin for 2 min after key is off if over 180. So you guys think I should just drop it to 180 from 185, Is that what i'm getting from you?
  10. #10 Re: Thinkin about a 165 degree thermostat
    A motor is hot because its a metal block with a zillion explosions going on inside it.
    So of course you are not going to able to just straight up touch things and expect them to not be hot, maybe you havent worked on many cars before.
    160 thermostat is stupid, you arent hot lapping this car on a track day.
    Run a 180 if the temp of the motor really concerns you, it will bring the temp down maybe 10-15 degrees but honestly the car won't know any different. Most PCM's dont care if the temp is 170 or 220, anything above or below those numbers is when the car will adjust parameters.
  11. #11 Re: Thinkin about a 165 degree thermostat
    May 2013
    Hortonville, WI
    I have worked on many cars, and know that things get hot. But im just askin if it was a good idea just to cool it down a little. I figured that running a little cooler would maybe make it a little happier givin it a little more life maybe. That's my main concern.
  12. #12 Re: Thinkin about a 165 degree thermostat
    SWPA
    Running too cold of a thermostat is BAD for an engine.
  13. #13 Re: Thinkin about a 165 degree thermostat
  14. #14 Re: Thinkin about a 165 degree thermostat
    May 2013
    Hortonville, WI
    ok that's fine I will leave it then. Just thought it would maybe make it last longer, and maybe run better. I will leave it the way it is then.. Thanks everyone!!
  1. 160 or 180 degree thermostat??
    By Sean1998Daytona in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2012, 07:05 PM
  2. 180 degree thermostat
    By IGGYS 2008 GXP in forum 5.3L V8 (LS4)
    Last Post: 05-07-2009, 09:47 AM
  3. GTP Question New To The 90 Degree Motor
    By 05grndprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2008, 08:15 PM
  4. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
  5. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
