Thread: Low oil level indicator
Results 1 to 4 of 4
  1. #1 Low oil level indicator
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    hey guys,
    Last night I was moving the 04 GP GTP out of the driveway, and the DIC said low oil level. After i stopped the car, checked the oil and the level appeared fine. Could this be a faulty sensor?
    I just got the car, won it at auction pretty cheap. only driving i have done on it is pretty much moving it off the tow truck to the driveway. I plan to do oil, filter, coolant, plugs and wires before putting it on the road. the interior is a little rough, but the engine bay is very clean. any advice is much appreciated.
    matt
  2. #2 Re: Low oil level indicator
    Pennsylvania
    Quote Originally Posted by orange57 View Post
    hey guys,
    matt
    Do the oil change and see where you are then, if the low level light continues to be a problem then maybe it's a sensor.
    Sport Edition Kv5 18x8
  3. #3 Re: Low oil level indicator
    If the dipstick reads properly, and the light is on, then check the wiring to the sensor. The sensor is located in the front side of the oil pan, between the starter and AC compressor. If the wiring looks good, I'd do an oil change and replace it.
  4. #4 Re: Low oil level indicator
    Aug 2012
    Chandler, AZ
    Thanks guys. Should get to the oil change over the holiday weekend....if I get the engine mounts replaced on my other car first
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. tcs off indicator and ABS indicator both on - why??
    By RealtyCaffeine in forum General Tech Discussion
    Last Post: 08-13-2009, 06:17 PM
