Thread: Rust Issues
Results 1 to 20 of 24
  1. #1 Rust Issues
    Jun 2012
    Canada
    Hi guys,
    I'm sure you've have had a few of these threads. I'm including pics so that hopefully it helps to see how bad (or not) the problem is. I am trying to figure out whether I should have the rust dealt with. Here is what is rusting:
    • Rocker Panels - I understand this is very common. I knew it when my passenger side panel started rusting about 6-7 years ago and I saw all the other GPs on the road with the same issue. The driver side panel held up well, but it's starting to rust now too. I had the passenger side panel cut out and replaced five years ago and it is now starting to rust as well. The body shop told me they had to fabricate a new rocker themselves because none were available for the GP unless I bought a new set of doors, and that was expensive! I'm kind of doubting this now, as I see by reading this forum that you can buy these things on eBay. And that's why I registered, to get some opinions on whether I should even bother. Cost of that repair was $800. Well worth it for the last five years of mostly no visible rust. I'd hate to see what that panel would look like today if I didn't have this done. What do you think I'd be looking at cost wise to do the same today if I bought the panels on ebay and had a body shop do the work? Looking at the car, it looks like there is some rust on the door and rocker panel cover too.
    • Gas tank door - I see from the common problems thread that this is also a bit of a known issue. I have a spot of rust under my door. It seems to be spreading slowly, or even not at all. Is there an easy way for a body shop to take care of this?
    The car is a '97 with 230km on it. Great car, fun to drive. Wish it didn't have rust.
  2. #2 Re: Rust Issues
    Grand Rapids, MI
    Not to get off topic, but where did you get those mud flaps? Can't find any like that anymore. And I'm curious to see pics of the rust under the gas door..
  3. #3 Re: Rust Issues
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    It's Canada. Rust is living the high life. It's not economically wise to spend that on rust repair on a 1997 Grand Prix though. That would be murdering good money.
  4. #4 Re: Rust Issues
    Jun 2012
    Canada
    Quote Originally Posted by brandonl2000 View Post
    Yeah, I didn't think to take a pic of that at the time. I'll take a pic of that this week.
    The mud flaps were purchased at a Pontiac dealer, at the same time I had the rocker fixed. The body shop was kind enough to install them for me. Just had to have them!
  5. #5 Re: Rust Issues
    Grand Rapids, MI
    *In reply to mechguy: Especially an SE that may or may not have a 3100?
    DR, have a part number for those flaps?
  6. #6 Re: Rust Issues
    Jun 2012
    Canada
    No! That's an insult!
    It definitely has a 3800.
    Guess I kind of knew that repairing this wouldn't be wise. I plan to keep the car for however long it lasts. 1 year, 2, 3, who knows? I don't mind paying under $1,000, if it's possible to take care of the rust for that amount.
  7. #7 Re: Rust Issues
    Grand Rapids, MI
    Well you're fine in my book then lol
  8. #8 Re: Rust Issues
    Waukesha, WI
    welding new patches and undercoating the **** out of it after wards to help prevent rust, you will never stop it, just slow it.
    for the gas door, theres a foam behind it that holds, salt, water, gas and causes the rust.. same thing weld in new patch and try and get undercoating behind to seal it.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  9. #9 Re: Rust Issues
    Jun 2012
    Canada
    Is the part number listed on the flap? If not I can check to see if I still have the receipt.
  10. #10 Re: Rust Issues
    Antioch, IL
    sand blast then re paint the area
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: Rust Issues
    Waukesha, WI
    be warned about that, sand blasting makes the metal thinner and it will rust faster
    RayRay
    92 Turbo miata
    02 lexus is300
  12. #12 Re: Rust Issues
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by redlinepontiac View Post
    You should probably just paint over the rust.
  13. #13 Re: Rust Issues
    Part it out...scrape the rest. Save and buy another gp with no or less rust. It's not smart to put the money into it that it's going going to cost to repair it correct. Plus Gp are a dime a dozen.
    04 Comp G.
  14. #14 Re: Rust Issues
    Antioch, IL
    All cars cost money. Makes more sense to fix something before it gets worse, then shell out more $$ for another car. Sand blast it, epoxy primer and paint. For the babies, paint remover disk, rust remover solution then throw on some kbs rust seal or eastwood encapsulator.
  15. #15 Re: Rust Issues
    GTX Level Member blackflag's Avatar
    Virginia
    I don't know guys, rust? Seems like a money pit. Have you checked your strut towers and such?
  16. #16 Re: Rust Issues
    Panama City Beach, FL
    Silly putty and Zaino will cover that right up.
  17. #17 Re: Rust Issues
    Ha,
    I used JB weld.
    Just buy a gray car, then you never have to paint it either.
  18. #18 Re: Rust Issues
    Willoughby, Ohio
    repairing it will be cheaper than buying another car, but as stated above WATCH THOSE STRUT TOWERS, i had to get rid of my GT when one of them fell thru due to rust
  19. #19 Re: Rust Issues
    Virginia
    Ok this is a 97 with 230km. It would be cheaper to buy another one with no rust, AND a s/c
  20. #20 Re: Rust Issues
    i wish my rockers look half that good.
  1. Gas Cap Rust.
    By DanPrixGTP in forum Visual/Body Modifications
    Last Post: 05-21-2012, 06:53 PM
  2. Rust
    By darionmilton in forum Visual/Body Modifications
    Last Post: 04-21-2012, 01:05 PM
  3. Rust!!! :(
    By Bluemagic in forum Visual/Body Modifications
    Last Post: 09-26-2011, 11:50 PM
  4. Rust!!!!
    By E IN v Y in forum Visual/Body Modifications
    Last Post: 08-14-2011, 03:41 PM
  5. Ive got rust
    By MikeZirpola in forum Visual/Body Modifications
    Last Post: 09-24-2009, 01:08 PM
