So tonight I was installing my zzp 1.9 rockers on my 01 gt. I forgot to disconnect the battery, while taking off the alternator I grounded out when my ratchet touched the fuel rail, i pulled my hand away to avoid being shocked and quickly found something to knock the wrench away, but in the meantime the wire the runs to the relay box that says fuse able link burned through and was smoking. I disconnected the battery and finished up the rocker install. I got it all back together taped up the hole in the fuse able link wire and attempted to start the car, everything in the car works, no fuses are blown, the fuel pump is turning on but the car just cranks but doesn't sound like it's got any spark. How much damage do you guys think there is? Any ideas where to start? Thanks.
Sent from my Z963VL using Tapatalk
