Fivefingerdeathpunch
Wiring harness should be super similar, not much will be different if anything. Depends on if the car has cali emissions or not.
You will need a 99+ throttle body and MAF sensor through if you are using the 2001 computer.
The motor will swap over fine.
Any transmission that is a 4T65e HD from 1997-2002 is a direct swap. 2003 was the change over with valve body and internal controls.
