Thread: Engine swap / Trans swap 2001 gtp v. compatible years
Results 1 to 20 of 33
  1. #1 Re: Engine swap / Trans swap 2001 gtp v. compatible years
    clean the piss out of it. then change all gaskets, but the heads. leave them on there.
    rockauto sells a felpro lower conversion gasket kit, has the pan, rear cover, front cover, both crank seals, w/p gasket oil pick up and the oil filter housing gasket. for like 30 bucks.
    re gasket the whole bottom end. and rockauto also sells the magnum lim gasket kit for like 40 bucks, comes with o rings and other gaskets.
    then wire wheel all the rust off. clean it with brake cleaner and paint it up the color of your liking.
  2. #2 Re: Engine swap / Trans swap 2001 gtp v. compatible years
    Mar 2014
    Tucson
    Unless it's yellow. Don't do that.
  3. #3 Re: Engine swap / Trans swap 2001 gtp v. compatible years
    what a groove looks like, if you see this, take a good look at the seal if its not damaged re use it. a new seal will leak with a repair sleeve.
    sleeve on pis is after it was ran for a while, and still leaked, so you can see the new score line the seal was making.
    this was a brand new seal. seems like it was dried out from sitting in a box for who knows how long. but its all busted up.
    good news is, changing the seal int he cars not all that hard really.
  1. Engine & Trans swap 05 GTP to 05 GT
    By mrlogic1234 in forum General Tech Discussion
    Last Post: 09-12-2013, 09:51 AM
  2. Swap 1997 GP GT engine and Tranny for 2001; Possible?
    By dkkgg2 in forum General Grand Prix Discussion
    Last Post: 09-25-2012, 06:25 AM
  3. GTP engine and trans swap into a 97 GT
    By CoolDavid in forum General Tech Discussion
    Last Post: 09-29-2011, 09:03 PM
  4. 98 GTP Trans Swap What years are compatable
    By Adamcc91 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-13-2011, 01:58 PM
  5. 99 to 03 engine and trans swap
    By topswap in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-17-2010, 08:35 PM
