Thread: Gtp PROBLEMS
Results 1 to 19 of 19
  1. #1 Gtp PROBLEMS
    SE Level Member 01grandpri's Avatar
    Oct 2015
    allendale michigan
    Hey guys I need help with some issues...2002 gtp 160k starts right up shifts fine..I have codes for bank 1 running lean..and high input at fuel pump.. Take it down the road and some times it acts as its running out of fuel.. Take it down the highway and almost acts like it is running out of gas.. I will get into it and it doesn't go at all when doing this problem just keep chugging... Help!
  2. #2 Re: Gtp PROBLEMS
    I'd figure out the lean code for one and check fuel pressure.
    Address those before something else happens and maybe you do damage to it.
  3. #3 Re: Gtp PROBLEMS
    Mar 2014
    Tucson
    Plugged fuel filter possibly?
  4. #4 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    It's my fathers car, the tail pipes on the car have a white film kind of deal on them..at high rpm I get a little white smoke..doesn't smell like oil or coolant. I brought it to the ZZP right down my road they said they don't know either.. He said the lean code can be my air filter but he doesn't know why I have white smoke at high Rpms.. How helpful lol
  5. #5 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    Update.. Car stalled out and won't start now! It cranks and cranks and gets spark but no fire!
  6. #6 Re: Gtp PROBLEMS
    My first post is still something you should look into.
    Check fuel pressure, check the fuel pump.
  7. #7 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    How do I check the pressure??
  8. #8 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    I know the fuel rail but what do I use to check it?
  9. #9 Re: Gtp PROBLEMS
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    White film/smoke = coolant. Sounds like hydrolock and a LIM job needed.
  10. #10 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    The white smoke isn't thick like normal blow intakes or heads..it just a small hint at 4,000 Rpms..the smoke doesn't smell like coolant
  11. #11 Re: Gtp PROBLEMS
    Dec 2008
    ****'s Creek
    Running lean is usually an intake or vacuum leak. When I got the lean bank 1 code it was due to the rubber vacuum fitting being cracked, there is a port on the LIM under the SC snout. When unmetered air dilutes the mixture, the O2 sensor reports a lean condition and the PCM attempts to adjust the injector pulse to compensate. When it reaches the max adjustment it can make and the mixture is still lean, it sets a code. Also check the throttle body gasket.
    Regarding fuel, look on the front of the fuel rail you will see what looks like a tire valve. This is where you would connect a pressure gauge. The fuel system is pressurized at all times even with the engine off. If you take off that valve cap and depress the Schrader valve (like letting air out of a tire) you should get fuel spray even with the engine/key off. If no fuel comes out then you have issues upstream with the filter and/or the pump.
    On a pressure test you would connect a gauge, turn the key on to activate the pump and see what the gauge reads. On the L67 fuel pressure should be 50-52 psi,
  12. #12 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    Just doesn't make sense why it won't start...it has spark..it spins over...it has to be pump or something..when I brought it to Zzp yesterday a guy came out and checked the vaccum lines and it was running..he said it sounds like the engine was running 100% fine.. That my lean bank 1 could be my air filter.. And white smoke that has no smell could be anything.. That I need to check pressure at fuel rail and coolant system and also smoke test the vaccum lines
  13. #13 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    Where can I find one of these pressure testerd
  14. #14 Re: Gtp PROBLEMS
    Jan 2014
    AR
    Quote Originally Posted by 01grandpri View Post
    Auto parts store. Surprise!
  15. #15 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    Quote Originally Posted by idrivejunk View Post
    Smart ass lol
  16. #16 Re: Gtp PROBLEMS
    Jan 2014
    AR
    Smart ass lol
    Thats was a fairly dumbass q.
  17. #17 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    Touché lol😂
  18. #18 Re: Gtp PROBLEMS
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I'm not an expert on PCM systems, but this sounds like crap. If you have a bad air filter, the car will be able to pull in less air, and then simply compensate with less fuel. If it didn't compensate, then you'd be running rich. Unless you have a goofy filter setup that throws off MAF readings, I don't see an air filter being related.
    I think FFDP is probably right on this. I had a 97 Lesabre that was throwing a lean code, and I completely replaced all the vacuum lines and ensured that there was no leaking anywhere. Tested the pressure at the fuel rail, and it was 20 PSI lower than it should have been. Replaced the fuel pump and filter and all was well.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  19. #19 Re: Gtp PROBLEMS
    Oct 2015
    allendale michigan
    Well fuel pump was grounding out and blowing the fuse..put new fuse and and pump.. Engine light went off and running like new! Thanks everyone!!!
  1. Problems
    By GrandPriest24 in forum Introductions/Noob Questions
    Last Post: 03-15-2013, 06:54 AM
  2. HUD Problems
    By ms3206 in forum General Tech Discussion
    Last Post: 09-20-2011, 10:32 PM
  3. think i would have problems?
    By gtp leslie in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2011, 08:57 PM
  4. KR Problems
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2010, 08:36 PM
  5. Having Problems...
    By GP3800TC in forum Turbo
    Last Post: 05-21-2009, 09:53 AM
