brettstoner
Sometimes if it isn't a clean break and I need to drill it I will use my dremel to flatten the bolt face before I punch it. Keep the bit or extractor from walking.
Those are low torque bolts so you should be able to walk them out with a punch or screwdriver. Tap tap tap. If it's stubborn I would drop the pan, save the fluid, and give you a little more room to work.
