Thread: Trans fluid question
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Trans fluid question
    Apr 2011
    North Los Angeles
    I just added trans fluid under 100 miles ago, i did NOT add a new gaskett and now i have a leak coming from the farthest most back position of the trans, i just want to verify i will be able to reuse that oil and filter, thanks.
    i also forgot to mention i complelty tore off the head off a bolt while tightening everything down there i didnt turn too hard but it happend, how can this be fixed?
  2. #2 Re: Trans fluid question
    Apr 2011
    North Los Angeles
    guys i really need help with this trans pan bolt and removing it. I took my drill to it and started to wear on the hole itself i have no clue what imdoing but i do know i need to get that out before i reinstall the pan
  3. #3 Re: Trans fluid question
    can you grip it with anything? It should come out easy as long as you didn't cross thread it.
    Next time torque the bolts to 10ft lbs.
  4. #4 Re: Trans fluid question
    Jan 2014
    AR
    When drilling a bolt out, the idea is to make a nice, straight, centered pilot hole with a small bit like 1/8" then step to the larger bit.
  5. #5 Re: Trans fluid question
    GTP Level Member
    Oct 2014
    Left handed drill bits work great if you can find them.
    Sent from my iPad using Tapatalk
  6. #6 Re: Trans fluid question
    Apr 2011
    North Los Angeles
    I threw it back on without it for now, I didn't have more time to today, I did use a different gasket and pan I'm not sure it fixed the leak though.
  7. #7 Re: Trans fluid question
    SE Level Member b4black's Avatar
    Oswego, IL
    Once you break the head off, it sometimes takes the pressure off the threads and it will easily come out if you can somehow spin it. Try getting something narrow and pointy, like an icepick, to back it out. (Might be too late if drilling boogered up the threads.)
    Make sure the leak is coming from the pan gasket and not the dipstick tube seal.
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  8. #8 Re: Trans fluid question
    Apr 2011
    North Los Angeles
    Ok I noticed it was still coming out the same this morning, so I'm sure it's not the gasket or the pan I'll double check that location.
  9. #9 Re: Trans fluid question
    Enfield, CT
    Next time, use a punch and tap the bolt out in the reverse direction with a hammer slowly. I do this with many broken bolts so I don't have to drill and use a helicoil. I've already had to do this with a trans pan bolt this year. This is the punch kit I bought and you only need to use one of them.
    http://www.lowes.com/pd_323749-16878...toreBeanArray=[com.lowes.commerce.storelocator.beans.LocatorStore Bean%40db80db8]&storeNumber=2386&kpid=3474069&cm_mmc=SCE_PLA-_-ToolsAndHardware-_-PliersAndWrenches-_-3474069%3AKobalt&CAWELAID=&CAWELAID=1368006997
    This will work very easily because there is no pressure on the broken bolt.
  10. #10 Re: Trans fluid question
    Enfield, CT
    To avoid any confusion, don't tap into the middle of the broken bolt, tap closest to the edge and tap away until it backs out.
  11. #11 Re: Trans fluid question
    Apr 2011
    North Los Angeles
    Quote Originally Posted by HighOctaneRacing View Post
    Thanks for the link, what do you mean by tapping it in reverse position? Im a noob at this
  12. #12 Re: Trans fluid question
    small chisel deal on the edge of the busted bolt kinda hard to do on a bolt that small. but you tap it out by unscrewing it.
    id get a center punch, punch the middle of the bolt, then use a left hand threaded drill bit/ extractor. the punch is so the drill bit dont wander all over, it will stay in the punched dot.
  13. #13 Re: Trans fluid question
    Enfield, CT
    1. Put the punch on top of the broken bolt near the edge
    2. Use a hammer and lightly tap the punch in the direction of which the bolt would come out which would be counter clockwise or reverse.
    3. Keep tapping the bolt in counter clockwise direction till the bolt fully backs out.
    You may be able to grab the bolt with some vise grips when it's halfway out and turn it counter clockwise.
    Sent from my LG G3
  14. #14 Re: Trans fluid question
    Apr 2011
    North Los Angeles
    The surface is very uneven kinda pointy the drill bit danced around and started to cut the hole itself so I stopped
  15. #15 Re: Trans fluid question
    Apr 2011
    North Los Angeles
    Sent from my LG G3
    Perfect description thank you.
  16. #16 Re: Trans fluid question
    Quote Originally Posted by steelholder View Post
    even on a jagged break you use a punch make the dot, then put the drill int he dot and start drilling, after its made a little hole you turn the drill bit straight and drill into the bolt. left handed drill bits spin backwards and spin the bolt out.
    cant find reverse drill bits? use a small normal drill bit and an extractor to remove it.
    try the punch and tap it out first, its kinda safe.
  17. #17 Re: Trans fluid question
    Enfield, CT
    LOL. it's kinda safe? it's 100% safe as long as you know what you are doing.
  18. #18 Re: Trans fluid question
    Apr 2011
    North Los Angeles
    Ok Scotty I'll try your method if punch doesnt work, I think it should though I saw it spin a bit with the drill
  19. #19 Re: Trans fluid question
    Jul 2010
    Coquitlam,BC,Canada
    Correct. And buddy you are helping knows what he is doing? LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Trans fluid question
    GTP Level Member
    Oct 2014
    If you can get a slot somehow put in the broken bolt (small dremmel) then back out with a screwdriver.
  1. Trans fluid change question
    By Dadillac in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-19-2014, 07:15 AM
  2. Trans Fluid Question
    By stevetiger2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-12-2014, 01:27 PM
  3. Trans and fluid question....
    By GoldGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-29-2012, 12:14 PM
  4. I guess a newb question about trans fluid
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2008, 02:00 AM
