Thread: Power steering low and high lines
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: Power steering low and high lines
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by ibra0078 View Post
    O really? Why?
    Chafing. Looks like they zap-strapped the two lines together. i'd put some plastic loom on the rubber line, just like the one next to it. Or if you have some larger hose, cut a small piece, cut it open to make it "split" and put over the hose in question.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #2 Re: Power steering low and high lines
    if the line moves while driving over time the hard line will rub a hole in the rubber hose. you can get some more hose, cut it open like a hot dog bun, put it over the hose and zip tie it on there, this way its rubbing the insulator hose you installed not the important one.
  3. #3 Re: Power steering low and high lines
    Jul 2010
    Coquitlam,BC,Canada
    Now that is a much better description. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Power steering low and high lines
    seemed like the best way to paint a picture lol
  5. #5 Re: Power steering low and high lines
    GXP Level Member
    Mar 2015
    Tomball
    I'm actually talking about where the 2 hard lines in your pictures touch, but solve it the same way...
    Jeff
  6. #6 Re: Power steering low and high lines
    Mar 2013
    Canada
    K thanks guys will fix the hard lines touching and the rubber one. Would plastic loom work fine for both or even a piece of a garden hose? Does the stock lines also touch like that?
    Sent from my SGH-I337M using Tapatalk
  7. #7 Re: Power steering low and high lines
    Jul 2010
    Coquitlam,BC,Canada
    Yes, those will work. Not sure if garden hose is flammable, so you may want to look at that before using it.
    They shouldn't. If they did, there probably would have been a recall on it. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Power steering low and high lines
    Mar 2013
    Canada
    Quote Originally Posted by Bronco Boy View Post
    Good point thanks
  1. What are these lines? Transmission? Power steering?
    By Drive XR7 in forum General Grand Prix Discussion
    Last Post: 10-17-2015, 09:49 AM
  2. high pressure power steering hose 2006 3.8
    By tajacks2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2015, 05:58 PM
  3. power steering lines
    By hardrocrick1 in forum For Sale - Parts
    Last Post: 03-08-2014, 02:41 AM
  4. Power steering high pressure line 04+
    By Javi in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2011, 09:37 AM
  5. Header hitting sway bar and power steering lines
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2011, 10:39 PM
