Thread: kr ???
Results 1 to 9 of 9
  1. #1 kr ???
    Jan 2015
    illinois
    what is an acceptable amount of kr , how much is dangerous
  2. #2 Re: kr ???
    if your stock you have kr already and its ok.
    once modded you want no kr at all.
  3. #3 Re: kr ???
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    There are many threads about this so i'll keep it short and sweet. If you're stock, you will have some KR. Once you start modding, and specifically, once you drop pullies and start adding boost you want none. Like 0. That's the goal.
    That being said I occasionally saw anywhere from 0-1.5* of KR before E85. Now i generally see values in the .89 and below range if at all. And my motor is still going strong. Each is different.
    The search button is at the top right btw.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: kr ???
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Having any kr is bad. none is amazing!
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  5. #5 Re: kr ???
    Jan 2013
    Raleigh, NC
    Damn you ninjaed me!
  6. #6 Re: kr ???
    Quote Originally Posted by chrsmi1 View Post
    im good like that lol
    and its not amazing to have no KR, its tuning. all i see is a blip at the shift of 0.4 to 0.8, some times i get a 1.1 when i let off the gas from going wot. other then that the rpm range is clean.
  7. #7 Re: kr ???
    Jan 2013
    leavenworth ks
    That's cause your the sh!t Scotty others can only try be as awesome as you
  8. #8 Re: kr ???
    it took me a while to figure this crap out. im far from the man tho lol owning the tuner is key tho. with out one you got no recourse at all.
  9. #9 Re: kr ???
    Even when modded to some extent, seeing 1º of knock is alright. That's not going to be enough at mid range power levels to cause damage, mid range being the standard 3.4 setup or around 10lbs of boost. The higher in power/boost you go the more that 1-2º of knock is more dangerous, then you'd better be more careful and hope you have closer to none. But it's still always possible to see ring butting or detonation and pop goes the ring land, then you have a junk motor.
