Originally Posted by Scottydoggs http://www.autocodes.com/p0418.html somethings up witht he air pump, check all the plugs to it. http://www.obd-codes.com/p0463 fuel level sender, but we knew about this one already. http://www.obd-codes.com/p0302 misfire on cylinder #2 i called that one. the 302 code was the same from the last engine ill try clearing it and seeing if it comes back. will it immediately show up again if it is a real misfire?
Forum Rules
