Thread: Swaping engine and trans from top ( first timer)
Results 1 to 20 of 645
  1. #1 Re: Swaping engine and trans from top ( first timer)
    http://www.autocodes.com/p0418.html somethings up witht he air pump, check all the plugs to it.
    http://www.obd-codes.com/p0463 fuel level sender, but we knew about this one already.
    http://www.obd-codes.com/p0302 misfire on cylinder #2 i called that one.
  2. #2 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    the 302 code was the same from the last engine ill try clearing it and seeing if it comes back. will it immediately show up again if it is a real misfire?
  3. #3 Re: Swaping engine and trans from top ( first timer)
    you said you had the fuel level sensor code before it blew up, not a misfire code.
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
