injector are in the fuel rail you unplugged them and plugged em back in, the wires for the injector could be damaged.
one coil fires two plugs, any coil will work it need not say #2 on it. if the icm is cheap take it too. yours could be bad.
what you can do now tho is swap the coil with the one next to it, swap the plugs so they are in the same place after the coil swap. see if the misfire moves, then you know its just a coil.
ill be doing this first thing tmrw morning
and if that #2 plug is not firing, it will be wet with gas when you take it out.
huh i would thought it was supposed to have gas all over it, i remember gas spilling out when i removed the old fuel rail from the line. Ill make sure that its dry.
