Thread: Swaping engine and trans from top ( first timer)
Page 33 of 33 FirstFirst ... 23313233
Results 641 to 645 of 645
  1. #641 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Does anyone know the locations of the torque converter circuit and the secondary air injection control A circuit. Maybe a diagram someone has handy? Thanks.
  2. #642 Re: Swaping engine and trans from top ( first timer)
    unplug what ever's in the way of it all coming out.
    tq circuits, what ever that is, its gonna be inside the tranny.
  3. #643 Re: Swaping engine and trans from top ( first timer)
    Mar 2017
    Internet
    If it's exhaust related.. it's easy enough to find. Lift the hood when the engine is cold. Fire it up and get your hands about an inch away from the connection points of the exhaust. From your description and mention of a new crossover, I'd bet you find the back a little loose. If that's the case, pop that off and put a new gasket in it, then tighten the bolts up.
    As for the 742.. remind those of us who aren't going to look it up what the name of it is. I'm thinking stuck tc soleniod, but you know...I'm guessing.
  4. #644 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Scotty did you mean unplug everything going to filter? If I did want to access the torque converter circuit would it be closer to pan area below?
    Bill, it's the torque circuit converter stuck off. Regarding exhaust flutter sound, I did get a new flange but not gasket going on other end leading to muffler maybe this is the culprit.
  5. #645 Re: Swaping engine and trans from top ( first timer)
    all them solenoids are in the side cover of the tranny.
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
