Thread: Swaping engine and trans from top ( first timer)
Page 14 of 33 FirstFirst ... 4121314151624 ... LastLast
Results 261 to 280 of 645
  1. #261 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I put the smaller axle in the passenger side it fit fine. What do you mean by rh?
  2. #262 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    Looks like the pickle fork got your boot.
  3. #263 Re: Swaping engine and trans from top ( first timer)
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by steelholder View Post
    RH means Right Hand, as in right hand side of vehicle sitting in the drivers seat.
    If you put the short shaft on the rh side, take pics. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #264 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    This ball joint laughs at me.I finally got it off the knuckle now I'm trying to replace. Does this set up look right? It doesn't turn anymore
  5. #265 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Quote Originally Posted by Bronco Boy View Post
    Lol that would be pic worthy yes but luckily i got the locations right
  6. #266 Re: Swaping engine and trans from top ( first timer)
    what am i looking at in the last pic? looks like a ball joint press but im not sure.
  7. #267 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Thats exactly right. I just realized the ball joint is welded onto the arm..and i dont have a grinder to take em off.
  8. #268 Re: Swaping engine and trans from top ( first timer)
    be easier to just change the lower control arm. it comes will all new bushing and ball joint.
  9. #269 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I see, I was just hoping it wouldnt be a 60 dollar fix.
  10. #270 Re: Swaping engine and trans from top ( first timer)
    bout a 100 for the pair shipped. buying them on line is way cheaper then local parts store.
  11. #271 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Pulled one from a wreck for 20. This place is like heaven even saw a complete wiring harness from an 04. I pulled this one from an impala 04 I believe it's the same
  12. #272 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Im almost sure ive got axles in the wrong place the driver side axle jams into the trans right before i could line up ball joint bolt with knuckle hole. It doesnt go far back enough just starts rocking the car back and forth. How frustrating..
  13. #273 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I was right the longer axle goes on the passenger side, shorter goes on driver side. Can anyone else confirm i think i was getting the opposite earlier want to double check
  14. #274 Re: Swaping engine and trans from top ( first timer)
    Apr 2015
    Muskegon, Mi
    That's what I was trying to tell you earlier.
  15. #275 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Quote Originally Posted by Troutman53 View Post
    you sure did I went back to that comment after switching them and saw you were right all along, thanks.
  16. #276 Re: Swaping engine and trans from top ( first timer)
    Apr 2015
    Muskegon, Mi
    You are welcome. Should be good from here on.
  17. #277 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Yeah everything seems to be going pretty good so far. Im reconnecting the wiring harness back to everything,most seem to fall in place. I am a bit concerned about the positive and negative cables that attach to the starter, ac compressor, alternator and . I made a huge mistake by not taking pics before removing bolts and nuts on these. I remember theres a negative somewhere behind the air injection pump bracket as well. I cant make a mistake on these guys. Any diagrams or ideas?
  18. #278 Re: Swaping engine and trans from top ( first timer)
  19. #279 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Dammmm Scotty back-at-it-again with the exact info I need. thanks
  20. #280 Re: Swaping engine and trans from top ( first timer)
    its been covered before, i just stole all the pics from another thread.
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
