Thread: Swaping engine and trans from top ( first timer)
Page 13 of 33 FirstFirst ... 3111213141523 ... LastLast
Results 241 to 260 of 645
  1. #241 Re: Swaping engine and trans from top ( first timer)
    Buffalo
    :th_thumbsup:
  2. #242 Re: Swaping engine and trans from top ( first timer)
    Buffalo
    my emojis don't work ?
  3. #243 Re: Swaping engine and trans from top ( first timer)
    id put a new gasket in there, get the old one off 100%. or it could leak.
  4. #244 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Dang i hope not everything lined up perfectly at that point.mill ge dhecking for leaks though. Does anyone have a diagram for the ac compressor?
    Edit my answer is on page 7 last post, remebered i had the same issue finding that last ac comp bolt when removing.
  5. #245 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Which side has the longer axle again?
  6. #246 Re: Swaping engine and trans from top ( first timer)
    pass side has the clip at the very end of the spline, the driver side clip is up further iirc.
  7. #247 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    so the driver side is the longer one passenger side is smaller?
  8. #248 Re: Swaping engine and trans from top ( first timer)
    i think so.
  9. #249 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    That driver side axle wooped my ass. I didn't get too far today, ac compressor, power steering and right side axle are in.
    The way I removed the driver side axle was by removing knuckle at the strut, I couldn't pop the joint off. That didn't work for installing, one the axle was in it was impossible to line up knuckle and strut, so now I'm back to the ball joint. With a long steel bar over the arm 300 pounds on top and heavy sledge hammer banging it doesn't nudge one bit. Any other ideas on how to get the axle in or remove the ball joint from hell?
  10. #250 Re: Swaping engine and trans from top ( first timer)
    is the tie rod popped free too? ive done it with the tie rod and strut un done. put the axle in the hub first, then line it up with the tranny.
  11. #251 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    no the rod was still on on the struts it was very very difficult to align the bolts at the strut, but perhaps the rod will free up some space. My specific problem was that once axle was in the hub and i raised everything up to the strut the lower bolt would align(with a schittload of force) then when i would apply force to align the top bolt it would somehow just stop and instead of lining up with hole it would start shoving the axle into the trans? what a pain, i even took off the bracket and rotor to lighten it up..
  12. #252 Re: Swaping engine and trans from top ( first timer)
    tie rod off and strut bolts off the knuckle flops around like a chicken with no head.
  13. #253 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    lol alright then, i cant wait to have that in tomorrow. everything seems to be going really slowly. I have another issue, one of the electrical plastic pieces that clips on to something came off at the wire (prbly happened when dropping in, cant find actual plastic piece) if it ripped off from the wire harness how can it be replaced?
  14. #254 Re: Swaping engine and trans from top ( first timer)
    you'll need to figure out where it goes to, then either get another plug and some wire off it from a junk yard and solder it on. or you can buy pig tails on line, but you need to know what its for.
  15. #255 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Here's a pic, that's the power steering on the side. that green one stems from the same location as the stripped one
  16. #256 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Edit double post just noticed
  17. #257 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    One last axle question before I get started again. I noticed that the passenger side axle has some play in it once installed. The driver side is very stiff with no play at all.I haven't fully installed it but had it in trans and hub and while trying to line everything up I noticed difference. Is this normal? I could feel the axle ramming into trans unlike the passenger side.
  18. #258 Re: Swaping engine and trans from top ( first timer)
    if you cant pull it back out its in right.
  19. #259 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Not sure when this happened..
    Here's a better pic of stripped wire, that green plug looks familiar maybe you guys can id. This is by the passenger side near power steering
  20. #260 Re: Swaping engine and trans from top ( first timer)
    Apr 2015
    Muskegon, Mi
    Just a heads up to save you some grief. The RH axle is the longer of the two.
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
