Thread: Swaping engine and trans from top ( first timer)
Page 11 of 33 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 645
  1. #201 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    another question,should i start out with mobile 1 synthetic? I know its pricier but i dont mind if its gna help performance and maintain it better, what do you guys think?
  2. #202 Re: Swaping engine and trans from top ( first timer)
    oils oil to me, i buy what ever's on sale. its your call in the end. you can if you want.
  3. #203 Re: Swaping engine and trans from top ( first timer)
    Buffalo
    Synthetics now, clean engine later
  4. #204 Re: Swaping engine and trans from top ( first timer)
    Don't forget a good filter
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  5. #205 Re: Swaping engine and trans from top ( first timer)
    Antioch, IL
    use junk chepo oil for the startup, then switch later on once its "rebroken in" and isnt a one start kaboom.
    2009 Challenger SRT8
    Expert at being gay.
  6. #206 Re: Swaping engine and trans from top ( first timer)
    Buffalo
    Huhs?
  7. #207 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Quote Originally Posted by ItHurtz View Post
    One start kaboom, no none of that hopefully. The price difference isn't too much I went synthetic. Have you ever had a one start kaboom
  8. #208 Re: Swaping engine and trans from top ( first timer)
    I've started one.. driven 5 miles and had it knockin.. One out of say 100+ engines. It's not super common to get a bad one. Can happen though.
  9. #209 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I m really hoping this doesnt happen.
    I bought a new radiator and so im taking a bit of a detour with installing that one. As for flushing the heater core do i just stick a hose in the hole till it runs clear? Im not exactly sure which hose leads to the core but im assuming its closer to the windshield side?
  10. #210 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    ^^^ they both go thru it. Do it both ways
    Sent from my iPad using Tapatalk
  11. #211 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    So just stick a water hose where the top radiator hose goes i to amd flush away?
  12. #212 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    Scotty has a great write up on how to flush somewhere on the forum. But to get the heater core directly flush the 2 heater hoses off the back of the tensioner bracket that the alternator bolts to.
  13. #213 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Put the new radiator in check out the disgusting sludge in my old one. This substance lines the interior of the heater core hoses. I really doubt water well remove the thicker material collected inside the core. I've tried before many times even used the store flushes and look.... I'd hate to have bought a new rad/hoses/pump only to have that filthy heater core slowly contaminate the system again.
  14. #214 Re: Swaping engine and trans from top ( first timer)
    yummy.
  15. #215 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    Death cool!
  16. #216 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    I was looking at the heater core replacement thread on this site, is there anyway to access those pics? I think this is the only way to make sure my entire coolant system starts of at 100% right? I know its a ton of work but im sure its sludged just like my rad. Would you guys replace given the circumstances?
    http://www.grandprixforums.net/threa...lacement/page3
  17. #217 Re: Swaping engine and trans from top ( first timer)
    id not change the heater core. the engine swap is less work lol but really, its a pita to change, not worth doing unless its leaking.
    id flush the piss out of it and call it good.
  18. #218 Re: Swaping engine and trans from top ( first timer)
    Apr 2011
    North Los Angeles
    Even if it has the sludge that was in my rad? I flushed the eff out of my radiator too and the nasty diarrhea sludge never came out, its heavy and just seems to settle in the bottom, i have my old rad upside down right now and the sludge just keeps running out, i really wonder what those flushes did..is there anyway i could stick wire brush/bore cleaner into the core kinda like cleaning a rifle barrel. would this work?
  19. #219 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    Use a brass sweeper nozzle to get some force nothing the flush.
  20. #220 Re: Swaping engine and trans from top ( first timer)
    GTP Level Member
    Oct 2014
    Behind
  1. 97 Grand Prix 3.8 Supercharged engine at local junk yard. Worth saving?
    By sgtmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2015, 08:38 PM
  2. Replies: 2
    Last Post: 09-30-2013, 11:34 AM
  3. Just bought an '05 with 100K that needs a new engine
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 11:35 AM
  4. wrecking 04 grand prix gt- alberta
    By turbo dave in forum Canada
    Last Post: 10-29-2011, 12:00 PM
  5. good salvage yard?
    By nitrostang21 in forum Off Topic Discussion
    Last Post: 09-13-2010, 04:53 PM
