Quote Originally Posted by jkazam1 View Post
Just programmed and loaded updates to my actron, and it pulled some codes. I have a PO520(oil pressure sensor), U1040, U1064, and a U1301. Is there a local fuse not in the fuse blocks????
from what i just got from googleing these code s the U1040 is causing all your problems, i would think your abs module has taken a turn for the worst.
U1040 Code - Car Forums and Automotive Chat
U1064 - Loss of Communications with DIM; what??
Im getting U1301 problem on the computer. So what do I need - JustAnswer
the oil pressure sensor in located by the oil filter, jack car up take off the pass side tire off, reach in with channel lock pliers to remove it, cost 10 to 12 bucks to replace from any parts store.
