Thread: EBCM replacement?
Results 1 to 7 of 7
  1. #1 EBCM replacement?
    SE Level Member grandprix85's Avatar
    Milwaukee, WI
    So I have a 2002 Grand Prix GT and i have the ABS & TRAC OFF lights come on and off. I had the lights scanned by a local car shop. They said i need to get the EBCM replaced and they said i can only go to a GM dealership to get it replaced and programmed. So I called one of the local GM dealerships and they said $1600 to get it replaced. I was like . So is there any other way around paying $1600? Is it easy to replace and program if I buy a used one from a junk yard?
    02 GP GT stock with tinted windows, 140K
  2. #2 Re: EBCM replacement?
    Grand Rapids, MI
    No. You don't have to go to a dealership.
    ModuleMaster does a great job rebuilding and warrantying our EBCM's.
    Check out my thread. http://www.grandprixforums.net/ebcm-...ion-50176.html
  3. #3 Re: EBCM replacement?
    Milwaukee, WI
    so im gonna be taking out the EBCM and shipping to them for a rebuild. thanks
  4. #4 Re: EBCM replacement?
    Jun 2012
    pa
    As an alternative, CheapABS in Virginia also rebuilds
  5. #5 Re: EBCM replacement?
    SE Level Member 2002grandprixgt's Avatar
    Jul 2012
    sioux city iowa
    i replaced a high presure power streering hose and started having problems with my abs system they told there two different hose could i have gotten the wrong one?
  6. #6 Re: EBCM replacement?
    Grand Rapids, MI
    You might want to create your own thread, this is a tad off topic.
    But keep in mind the EBCM is not only responsible for abs function, but also determining the functioning of the magnasteer rack. Not sure if the lines are different for Magnasteer or without, but it's worth looking into? I believe the lines are the same though, probably just coincidental.
  7. #7 Re: EBCM replacement?
    Jun 2012
    pa
    wrong thread
  1. EBCM (Electronic Brake Control Module) Replacement, ABS Light/TCS Off Solution
    By brandonl2000 in forum How To Write-Ups/Tech Tips
    Last Post: 02-05-2022, 07:51 PM
  2. Quick question about the EBCM
    By tmgray01 in forum Brakes/Suspension/Chassis
    Last Post: 07-16-2012, 01:32 AM
  3. Question about EBCM repair.
    By sk8erdude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2012, 03:02 PM
  4. EBCM & North* TB
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 10-14-2011, 01:22 AM
  5. How To (Un)Install EBCM
    By SlowNA06 in forum How To Write-Ups/Tech Tips
    Last Post: 09-25-2011, 11:51 AM
