Thread: ABS/Traction/Brake lights on
Results 1 to 20 of 29
  1. #1 Re: ABS/Traction/Brake lights on
    Jun 2012
    pa
    Just programmed and loaded updates to my actron, and it pulled some codes. I have a PO520(oil pressure sensor), U1040, U1064, and a U1301. Is there a local fuse not in the fuse blocks????
  2. #2 Re: ABS/Traction/Brake lights on
    Quote Originally Posted by jkazam1 View Post
    from what i just got from googleing these code s the U1040 is causing all your problems, i would think your abs module has taken a turn for the worst.
    U1040 Code - Car Forums and Automotive Chat
    U1064 - Loss of Communications with DIM; what??
    Im getting U1301 problem on the computer. So what do I need - JustAnswer
    the oil pressure sensor in located by the oil filter, jack car up take off the pass side tire off, reach in with channel lock pliers to remove it, cost 10 to 12 bucks to replace from any parts store.
  1. ABS/Traction control lights
    By thirdrail37 in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2011, 01:00 AM
  2. abs & traction lights
    By uNda6gT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 03:06 PM
  3. ABS & Traction Control Lights
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2009, 06:40 PM
  4. ABS/Traction Lights On
    By Strype in forum General Tech Discussion
    Last Post: 10-01-2009, 07:50 PM
  5. '99 GT - ABS/Traction Control Lights
    By Sparg93 in forum General Tech Discussion
    Last Post: 01-15-2009, 06:21 PM
