Pulled all (4) wheels, checked connectors and wiring. All appears to be good, with no obvious damage. WD-40'd the connectors. All wheel bearings seem fine too, with no noise or play. Checked all fuses, OK. (Don't have a cig lighter fuse, but both Aux power outlets are working). Checked and topped off brake fluid. I have seen the ABS light before, such as when I did have a bad wheel bearing, but for all 3 lights to come on at once????????? They will come on in the DIC as soon as I start the car. I can reset them in the DIC while driving, however, the lights in the dash panel remain lit........
