Quote Originally Posted by randys100 View Post
I think all signs are pointed to the right side. Would a bad axle cause vibration in braking too? It's strange, the vehicle has no vibrations driving around town at 45-50 mphs. All the symptoms occur at higher speeds > 65 mphs.
how old are your tires? if you have a friend with the same tire and rim size, swap out the fronts with him, tires dont last for ever, and sometimes suck.
theres a guy here had similar problem, turned out to be a bad tire. found it on a high tech balancer of some sort.
