Thread: Oil leak and vibrations
Results 1 to 3 of 3
  1. #1 Oil leak and vibrations
    SE Level Member littlerobinson75's Avatar
    wrentham, MA
    Hey guys, i have a 98 gtp and about a month ago i noticed oil spots under my car and some oil coming from my intake. I replaced the PCV valve and the major oil leak from my pan was due to the gasket on plug was gone. i still have a minor leak and now there's some odd vibrations at idle about 50% of the time when i start the car but go away when i put it in gear. there is the occasional hard start too. Other peoples advice would be much appreciated.
    thanks
  2. #2 Re: Oil leak and vibrations
    Look for the leak, then fix the leak.
    Consider when your last tune up was and probably change plugs/wires.
    Smile..your car is running great and leak free.
  3. #3 Re: Oil leak and vibrations
    wrentham, MA
    hey thanks ill check for the leak i just got back from vacation, hopefully i can find it. the plugs and wires are relatively new, i checked them not too long ago and looked good but ill double check them
  1. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  2. Very noticeable vibrations when not moving in drive
    By xsvtank in forum General Tech Discussion
    Last Post: 12-27-2010, 04:47 PM
  3. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  4. INFO:People w/ Poly Mounts and Vibrations
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-31-2009, 05:43 PM
  5. More vibrations
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 12-19-2008, 08:28 PM
