Thread: Front end Hum: pitch is related to vehicle speed
Results 1 to 9 of 9
NoTyme Front end Hum: pitch is... 03-29-2010, 09:30 AM
Bio248 Re: Front end Hum: pitch is... 03-29-2010, 09:33 AM
gpgtman83 Re: Front end Hum: pitch is... 03-29-2010, 09:37 AM
NoTyme Re: Front end Hum: pitch is... 03-29-2010, 12:00 PM
Lawngoose Re: Front end Hum: pitch is... 03-29-2010, 01:01 PM
NoTyme Re: Front end Hum: pitch is... 03-29-2010, 01:36 PM
gpgtman83 Re: Front end Hum: pitch is... 03-29-2010, 10:45 PM
NoTyme Re: Front end Hum: pitch is... 03-30-2010, 08:13 PM
NoTyme Re: Front end Hum: pitch is... 03-31-2010, 09:26 PM
  1. #1 Front end Hum: pitch is related to vehicle speed
    SE Level Member NoTyme's Avatar
    southeast Michigan
    My wife’s 2002 Grand Prix has a nasty sounding hum in the front end, possibly towards the right side but I am not sure. It changes pitch with the speed of the vehicle not with the speed of the engine and while rolling and popping it into neutral the hum is not affected. I have drove in a parking lot and turned from side to side to see if the hum was louder in either direction and while driver down the road at 35 or 40 mph and I can’t make a definitive change in the noise.
    Now we changes the front hub assemblies in 11-08 at 60,700 and now 16 months later at 75,000 I am getting this hum.
    The hubs were changed because the car did wander a bit but that is not an issue this time. Anyone have any ideas?
  2. #2 Re: Front end Hum: pitch is related to vehicle speed
  3. #3 Re: Front end Hum: pitch is related to vehicle speed
    united states
    mine was doing the same thing about a week ago so i changed the cv shafts and the sound is gone
  4. #4 Re: Front end Hum: pitch is related to vehicle speed
    southeast Michigan
    Quote Originally Posted by gpgtman83 View Post
    I was thinking about that: there a u-joint looking part correct?
    How much work was it to change it out?
  5. #5 Re: Front end Hum: pitch is related to vehicle speed
    Outer Space
    hmmm.. interesting... Mine has down this ever since i did a tranny swap. But mine only does it on decel and is loudest in the 40-50 mph range.
    My CV axles are warrantied from NAPA, but I didn't know if was wheel bearings or axles. My wheel bearings have never been replaced and I have 146k on my car ... no ABS lights or anything.
    02 GTP 13.6 @ 100mph - SOLD
  6. #6 Re: Front end Hum: pitch is related to vehicle speed
    southeast Michigan
    Lawngoose,
    Actually I did hear a bit, just a small droan after the hubs were replaced but I don't drive the car regularly. My wife has made numerous trips in the last year since we did the hub replacement up to 70 miles from home quite often but normally drives 10 miles to work and then back.
    She told me this morning to listen to the car as it seems to be getting loud... Wow! Its noticeable...
    With the hubs I was able to make the noise louder by turning in one direction or another, but not in this case. I did crawl down there and try to see if one had more play than the other but with the car on the ground I could not tell any difference from one side to the other. Both were pretty solid.
  7. #7 Re: Front end Hum: pitch is related to vehicle speed
    united states
    it was not that bad of a job to do i went ahead and replaced hubs at the same time since i had it apart there is a write up on cv shaft replacement in the how to section of this site
  8. #8 Re: Front end Hum: pitch is related to vehicle speed
    southeast Michigan
    Well, I broke down and took it into the local garage that I have dealt with. I'll know by tomorrow evening and I'll post results... Not sure if I want to crawl down there and pull front end apart without knowing for sure if its the culprit.
  9. #9 Re: Front end Hum: pitch is related to vehicle speed
    southeast Michigan
    I had to replace the driver's side hub, again... I had the car into Michel Tire in Nov 08 and after 15,000 and within 16 months the driver's side failed. That was $468 for both hubs and they also got me for an alignment, another $50. So much for their cheap parts...
    I had a local garage install a NAPA hub with a lifetime warranty. Total was $295...
    I just didn't feel like breaking my knuckles on this one.
  1. Vehicle Speed Sensor????
    By Luminary in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2022, 01:38 PM
  2. Vehicle Speed Sensor
    By bct717 in forum Chevrolet Monte Carlo
    Last Post: 12-08-2010, 08:39 PM
  3. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  4. Left turn high pitch Squeel
    By drumboy722 in forum 04+ Specifics
    Last Post: 10-07-2009, 03:49 PM
  5. non gp related question
    Last Post: 05-20-2009, 07:15 PM
