Thread: Front end vibrations at high speed and braking
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Front end vibrations at high speed and braking
    Quote Originally Posted by randys100 View Post
    Yet another update. The dealer inspected the car again, claims the vibrations could be a bad tire. They road forced balanced and rotated the tires. All the tires balanced out correctly. Yet, the vibrations are still there. The dealer said nothing was wrong with the suspension/front end parts. All the components checked out good. I'm at a loss with this vehicle. I don't want to throw money at tires if that's not going to solve the problem. The car sounds like a semi truck driving down the road....
    you need tires!
  2. #22 Re: Front end vibrations at high speed and braking
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    prolly a bent rotor
  3. #23 Re: Front end vibrations at high speed and braking
    Sep 2011
    Michigan
    Possible, but wouldn't the balancing catch that?
  4. #24 Re: Front end vibrations at high speed and braking
    Sep 2011
    Michigan
    you need tires!
    I'm suspecting that, but not sure. Im still surprised they'd balance out so well. Plus they're Mich. Tires, which the dealer claims are good tires.
  5. #25 Re: Front end vibrations at high speed and braking
    he just put new rotors on it.
    his tire are most likely messed up, the steel belts tent to unwind under the rubber. his tire may even have a hop to it, or egg shape, but cant see or feel it till its going 60 mph.
    i had i tire like this on my car when i bought it, thought it was a bent rim, but the tire was egg shaped when spinning fast. most tire balance machines don't do 60 mph, so you cant tell, they still balance on the machine.
  6. #26 Re: Front end vibrations at high speed and braking
    Sep 2011
    Michigan
    Yeah, two sets of rotors in fact. Some very good points here. I'll pop in to a tire store tomorrrow.
  7. #27 Re: Front end vibrations at high speed and braking
    Sep 2011
    Michigan
    It turns out the balance was way out of whack along with two bent rims. The dealer that said they road forced balanced the tires obviously did not do the job. After a visit to Discount Tire today I quickly learned the tires were seriously out of balance. Thanks for the advice and suggestions.
  8. #28 Re: Front end vibrations at high speed and braking
    How were the calipers? Did the guide pins slide freely in the calipers?
    On the topic of warping: Most of the time its cheap pads.
    EBC reds and econo rotors here. Stock 10.92" rotors as well.
    No warping.
  9. #29 Re: Front end vibrations at high speed and braking
    Donating Users
    South Deerfield, MA
    ^^ This. Cheap pads can ruin a set of rotors fairly quickly. Cheap pads can ruin a set of cheap rotors even faster. I did the brakes for my neighbor on their minivan. She wanted to use the cheapest stuff. Three months later, she was asking me to do it over with better parts because she couldn't stand the squeeling and vibration anymore.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. Random very high / fast idle speed...
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2013, 10:55 PM
  2. Oil leak and vibrations
    By littlerobinson75 in forum General Tech Discussion
    Last Post: 08-20-2011, 06:25 PM
  3. Front end Hum: pitch is related to vehicle speed
    By NoTyme in forum General Tech Discussion
    Last Post: 03-31-2010, 09:26 PM
  4. More vibrations
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 12-19-2008, 08:28 PM
