Thread: pulling under WOT
Results 1 to 13 of 13
  1. #1 pulling under WOT
    Donating Users JESSEGOTTA GP GT's Avatar
    NC
    I was driving last night and floored my car for the first time in a while and couldn't hold it on the road..... It pulled left and right and all over. I did notice the rubber piece on The tie rod end looks like it exploded because it got grease all over everything. I thought i read somewhere that it might be the struts but i don't remember.....
    New project: 2000 Red GTP.
  2. #2 Re: pulling under WOT
    have some one crank on the steering wheel while you watch the tie rods, if they are shot you will see it move with out the steering knuckle move, do this with the car off. crank the wheel back and fourth 3 inches each way.
  3. #3 Re: pulling under WOT
    NC
    The ABS light came on last night if that has anything to do with it?
  4. #4 Re: pulling under WOT
    jack the front end up and shake it down.
    Movement at 3 and 9 is bad ti rods and movement at 12 and 6 is wheel bearings.
    and if the abs came on thats a wheel bearing issue.
  5. #5 Re: pulling under WOT
    Feb 2009
    flintnasty MI
    steering issues under heavy acceleration ONLY is caused by lower control arm bushing failures.
    A blownout tierod would cause steering issues and noises at all times.
  6. #6 Re: pulling under WOT
    NC
    I think I'm just gonna sell the damn thing.
  7. #7 Re: pulling under WOT
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Get some new LCA's.........Not very expensive at all...
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  8. #8 Re: pulling under WOT
    New LCA's and Tie Rods shouldn't run more than a couple hundred bucks AT MOST.
  9. #9 Re: pulling under WOT
    NC
    ABS light is off, and it makes no noise while driving. I think I'll just start re-building the front end steering/suspension componets. If anyone has any suggestions for lowering springs/ replacement parts post some links up.
  10. #10 Re: pulling under WOT
    utah
    Dna springs for sure
  11. #11 Re: pulling under WOT
    NC
    I wanted to get the DNA springs, but everybody told me I wouldn't be happy with them and I'd wanna go lower.
  12. #12 Re: pulling under WOT
    Wichita
  13. #13 Re: pulling under WOT
    NC
    too much money! I'd buy a used set anyday.
  1. Pulling the AC
    By protoplayer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2011, 09:53 AM
  2. Harmonic balancer pulling
    By own one in forum General Tech Discussion
    Last Post: 03-13-2011, 12:19 AM
  3. Pulling my engine
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2009, 01:07 PM
  4. Pulling a Pulley
    By jagamite in forum General Tech Discussion
    Last Post: 11-14-2008, 08:12 AM
  5. FWI without pulling the bumper.
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 05-14-2008, 08:35 AM
