Thread: Brakes grabbing intermittently
Results 1 to 7 of 7
  1. #1 Brakes grabbing intermittently
    Aug 2011
    Modesto, CA
    Been having some braking problems. new brakes(on front)
    brakes grabbing intermittantly - Chevy Dealer put
    New Hubs & Bearings - seemed to fix the problem for a short while
    Still happening. Been told most likely ABS system problem-
    also told to put on new brakes in rear to see if that fixes problem.
    If not, then ABS problem - Any thoughts
  2. #2 Re: New - 2004 GP GT Owner
    Omaha, NE
    Welcome to GPF.
    ABS is built into the wheel bearings.
    It sounds like your brakes need to be bled, or fluid checked.
    Did the dealer do pads and rotors?
  3. #3 Re: Brakes grabbing intermittently
    Florida
    Simplest thing would be a warped rotor... when you say new brakes, is it new rotors and pads, or just pads??
    2nd would be an air bubble in the brake lines.
    Also, if it were abs, they'd be able to pull an abs code on it.
  4. #4 Re: Brakes grabbing intermittently
    Abs light on? Brake light on?
  5. #5 Re: Brakes grabbing intermittently
    Aug 2011
    Modesto, CA
    THE ABS & Traction Control lights were on intermittantly
    prior to the installation of the Bearings/Hubs - Have not
    come back on since - although problems remain
  6. #6 Re: Brakes grabbing intermittently
    Aug 2011
    Modesto, CA
    Invoice shows brakes and turning the rotors
    on the front only
  7. #7 Re: Brakes grabbing intermittently
    St. Louis
    Try removing both the caliper bolts and greasing them up really well w/ some high-temp disk brake grease and reinstall. Might just be a caliper sticking. Happened on my Bonne.
  1. HUD works intermittently
    By Phyrstorm in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2012, 09:08 PM
  2. HUD working intermittently ('97 GTP)
    By Powertrike in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2010, 09:07 PM
  3. HUD and GPS going out intermittently?
    By Jas0n in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2010, 08:22 PM
  4. Key intermittently won't come out of ignition
    By atclarkson in forum General Tech Discussion
    Last Post: 06-09-2010, 09:47 AM
  5. Low Oil Level Warning on Intermittently
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 10:09 AM
