Thread: Harmonic balancer pulling
Results 1 to 6 of 6
own one Harmonic balancer pulling 03-12-2011, 10:30 PM
matt5112 Re: Harmonic balancer pulling 03-12-2011, 10:40 PM
own one Re: Harmonic balancer pulling 03-12-2011, 10:53 PM
own one Re: Harmonic balancer puller 03-12-2011, 10:59 PM
matt5112 Re: Harmonic balancer pulling 03-13-2011, 12:07 AM
Explicit_Spade Re: Harmonic balancer pulling 03-13-2011, 12:19 AM
  1. #1 Harmonic balancer pulling
    p.cola fl
    i need to pull my harmonic balance
  2. #2 Re: Harmonic balancer pulling
    which engine?
  3. #3 Re: Harmonic balancer pulling
    p.cola fl
  4. #4 Re: Harmonic balancer puller
    p.cola fl
    i tried using a breaker bar didn,t work
  5. #5 Re: Harmonic balancer pulling
    impact?
  6. #6 Re: Harmonic balancer pulling
    Omaha, NE
    Everyone is having problems with these damn things the past few days, myself included.
    I'm assuming you're still working on the bolt. Remove and or partially break the plastic around the starter where it meets the flywheel. Hold the flywheel with a solid (craftsman is the best I've tried so far) Screwdriver or I've heard vicegrips.
    From there try a breaker bar, if that doesn't work, try an impact. If that doesn't work... put the breaker bar somewhere it'll be solid, plug the battery back in and turn the key to ignition and it should come off from what I've heard.
  1. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  2. Harmonic balancer puller
    By TorqueAutoMotiv in forum Shops and Community Heroes
    Last Post: 10-02-2010, 03:49 AM
  3. Harmonic balancer question
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2009, 04:52 PM
  4. Any advice removing old harmonic balancer?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-09-2009, 06:35 PM
