Thread: When to replace struts?
Results 1 to 5 of 5
  1. #1 When to replace struts?
    Nov 2009
    California
    My 2001 has 98K miles, mostly driven city miles. How do you determine if it's time to replace the front struts? Front end seems firm when given the bounce test. You can really feel it when going over even mild potholes and bumps. Any comments? Thanks
  2. #2 Re: When to replace struts?
    Charles City, IA
    Open the the hood and bouncy the car and see if the strut mounts move up or down at all. If not they are probably ok yet. Mine are junk now at 150k.
    SMGPFC Two Nipple General
  3. #3 Re: When to replace struts?
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    well, you'll probably know if it needs them just by driving it. If you feel like the ride quality has gone down alot then you definitely need them, I did mine at about 130k...If you are still on the originals then its safe to say that it's time for some new ones.
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  4. #4 Re: When to replace struts?
    Jul 2010
    upstate NY
    Outside of mounts or spring isolators going bad (as 01GTP refers to), if you are getting a slight floaty response after going over a dip, pothole or anything else that moves the springs, then its time. Having said that, my '99 went over 100k miles without a need for struts while my '05 needed them at 70k miles. Same roads so quality is going down. The bounce test is a gross "see, I told you so" type of test and your handling actually starts suffering when that float starts creeping in.
  5. #5 Re: When to replace struts?
    the float is terrible.
    I have the float and i'm around 85 K miles.
    Its not bad but its there.
    Since you mention city miles... chances are you need new struts.
  1. Need new struts
    By Will5600 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2010, 11:01 AM
  2. 97-98 struts vs 99-03 struts
    By joshua_arndt in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2010, 02:44 PM
  3. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  4. Need new struts
    By hunter_alexander in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2008, 09:41 PM
