Thread: New struts in
Results 1 to 18 of 18
  1. #1 New struts in
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    All four corners got Monroe Quick Struts this past weekend. They appear to have raised the car body about 1/8" when I measured before and after. The roads have been snowy and crappy since then, so I can't say whether the ride is improved or not, but the OEM ones were shot, anyhow.
    Still have a rattle in the rear, though. Where should I start to look now? I'm thinking trailing arm mounts or lateral bar mounts.
  2. #2 Re: New struts in
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Sweet. If the bad ones were bad, they were probably sitting low. On the other hand, sometimes new springs need time to settle in. I wouldn't worry about the lift. N/E how. Enjoy those struts. I heard a lot of good about them
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  3. #3 Re: New struts in
    Apr 2009
    I can live with 1/8" with no worries, even if they don't settle. Front tires already rub when turning and rears rub when going over hard bumps. I really need to roll the quarters
  4. #4 Re: New struts in
    whoa...why are you rubbing on a stock suspension? something is wrong..
  5. #5 Re: New struts in
    Apr 2009
    Offset on non-stock 17" wheels and bigger tires.
  6. #6 Re: New struts in
    Hows the tire to strut clearance?
  7. #7 Re: New struts in
    Apr 2009
    you know what, matt, I didn't even think to check if it was different on these new struts. The wheel wells are full of snow now, so once it melts off, I'll have to check. Thanks for the reminder
  8. #8 Re: New struts in
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    I HATE the Monroe Quick Struts...I replaced my original struts about 2 months ago with the Monroe's and now I drive a lifted Grand Prix...hate them so much, they make the car look like crap...Not quite sure what I can do I'm not going to drop another $500 on different struts when these are pretty new.
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  9. #9 Re: New struts in
    Quote Originally Posted by Dtrick22 View Post
    You're funny....
    Thats what stock grand prix's rode like.
  10. #10 Re: New struts in
    Apr 2009
    After putting a few hundred miles on them, they have settled to what seems to be a little below where the OEM ones were, just judging by the amount of additional rub I have now when I turn the front wheels.
    Edit that. I just measured them out of curiosity. They're equal to or 1/8" lower than the OEM struts. They seem to handle fine, although it's still hard to say with the crappy roads we'll have until about April.
  1. Struts for 04 GTP
    By ionroller in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 12:43 PM
  2. Need new struts
    By Will5600 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2010, 11:01 AM
  3. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  4. Struts!!!!
    By MizzBecca in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2009, 11:52 AM
