Thread: run the power cable from battery to trunk - FINISHED!! PICS!
Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
  1. #41 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Quote Originally Posted by blackbonnie View Post
    when you are fusing something, you wanna fuse to the size of the wire, not to the size of the amps, alternator, etc...
    reason being is because if you fuse over the size of the wire, then you run the potential of burning up the wire, starting a fire, etc.
    your amps fuse/fuses, or your fuse box fuses will take care of themselves and blow when the max current is reached. thats there job. no reason to do the same job twice. (unless your amp does not have any on board fuses, then you will fuse to the necessary amperage the amp will pull.
    fyi, 1/0 is rated (usually at max) 300 amps.
    How will the Locx improve my sub setup versus the hipass?
    Also, Im running a 4 gauge wire from battery to trunk. If I am not mistaken I have a 60 amp fuse by the battery in a 50 in the back. I have a feeling that they are to large but I may be mistaken. What do you think I should run?
    Thanks again!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #42 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    SE Level Member blackbonnie's Avatar
    Jan 2009
    grand rapids, MI
    Quote Originally Posted by Freebeer187 View Post
    Thanks again!
    basically it wont really improve anything, using the high pass on your amp does basically the same thing as a loc would. the only way to improve your setup is to buy an aftermarket head unit and install that. that is the best route to go. but your route is not bad, its just not the most ideal.
    and 4 guage can carry up to 150 amps of current, so i would recommend that you run one single 150 amp fuse at the battery and forget about the other fuse in the trunk (unless you are stepping down in wire size, or you have a second battery back there)
  3. #43 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    Bartlett, IL
    Thanks for the info once again.
    The only reason why im running the fuse in the trunk is to lower the gauge of the power wire.
    4 gauge is too big for my amp. If I am not mistaken, the Alpine i am using is for interior speakers, but does have a 2 channels for subs.
    One more question for you. The locx is a two channel to rca. At the moment I am running just one channel to the sub (right stock sub channel to one channel hi pass). Should I run both the left and right stock sub channels into the locx?
    How To: E-Brake Pwn
  4. #44 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    okay, im trying to run my 8 guage wire through the top gromet(the one that you can access from the engine bay. how in the hell am i supposed to fit that wire through that tiny freaking hole. i just got done trying for about and hour and i cant fit the damn thing through. Am i supposed to take out the grommet??
    SPREAD THE JAM
  5. #45 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    Feb 2009
    Illinois
    anyone?
    SPREAD THE JAM
  6. #46 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    TDCRacing
    Guest
    Do you happen to have a picture?
    Is the actual hole to small or is it just the grommet. Can you slice the grommet open a little further to get the wire in?
  7. #47 Re: Where to run the power cable from battery to trunk
    Feb 2009
    Illinois
    This is the grommet. i tried everything that has already been posted in this thread. is there a trick to it?
    SPREAD THE JAM
  8. #48 Re: Where to run the power cable from battery to trunk
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by redprix View Post
    Negative ghostrider, I don't know of anyone that has used that grommet. Look under the glovebox and pull up the carpet, there you will find a square rubber plug. It's pretty much right where you would rest your feet in the passenger seat. Its a 2 piece plug, the plug you want to take out and make the wires go through seperates from the rest of the plug, just pop the center piece out.
  9. #49 Re: Where to run the power cable from battery to trunk
    Feb 2009
    Illinois
    And once i do that where will the wire i fed end up? and is this the rubber plug your talking about? i just remove the center?
    SPREAD THE JAM
  10. #50 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Hey, just a suggestion, Try turning your sub box around. My box is allot bigger, but I have always had better luck with bass in every car I've done with the sub facing the back of the car.. try it out... if you like it, let me know!
  11. #51 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    Feb 2009
    Illinois
    yea, ill try that. do you know where that rubber plug feeds too?
    SPREAD THE JAM
  12. #52 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    Jan 1970
    Maquoketa, Iowa
    Its part of the firewall, it will end up below that other plug you wanted to use and a little closer to the side of the car. I think I was able to reach the plug on both sides with me laying under the door but I'm pretty tall.
  13. #53 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    Feb 2009
    Illinois
    thanks, ill try it tomorow and post if i got it or not
    SPREAD THE JAM
  14. #54 Re: run the power cable from battery to trunk - FINISHED!! PICS!
    Feb 2009
    Illinois
    Hey, i actually got the wire to fit through that grommet i wanted to use in the first place. here is a pic.
    SPREAD THE JAM
  1. Battery Compartment Mount
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 09-08-2008, 05:37 PM
  2. Convert a GP to battery power. Could it be done?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-03-2008, 09:24 PM
  3. Finished Gen V Install Pics
    By Street Wolf in forum General Tech Discussion
    Last Post: 07-20-2008, 07:33 PM
  4. Interesting battery
    Last Post: 07-07-2008, 10:07 AM
  5. Small battery
    By Arkanzan Wheeler in forum General Tech Discussion
    Last Post: 05-24-2008, 10:33 PM
