Heres my setup (so farstill have several things i'm gonna clean up n trick out!!)
I wish i would have thought about a sub showing through that trunk opening. I just have a small amp exposed =/
The back plate for the cup holder is just held in place with bolts sticking out about 3/8 inch on each side. If you wedge a screw driver (or really small crowbar like i did) you can just pry back a lil n clear the bolt end n take out that panel.
See the small bolts tip at the bottom?
I don't like exposed amp power wire, so i hid it pretty well
The fuse n wire hidden behind the bat
New (well for me anyways) AVIC D3.. Just got it, n waiting for a couple of accs to arrive for it
The 4Channel membrane swith to control the amps rem (among other things)
The relatively powerful but small mtx 282 exposed through the rear cupholder/armrest
N last but not least dual MTX 4500 12's. Please dont comment on how i'm gonna burn the amp. i'm aware of it
