I am putting in a transit blu hf. It needs a 12v switched power source. I bought a fuse tap and did this before, but I can't remember which one is switched.
Yeah. Where is the wiper fuse?
2006 grand prix gt
The sunroof is switched? I could use that since I don't have a sun roof.
Doesn't the radio stay on with the RAP?
My fuse tap is 2-10 amps. The sunroof is 20, but since there is no sun roof, does it matter?
sun roof is more then likely blank inside the fuse block.
when using a add a fuse, your still using your amp fuse with it. as well as the spot your using to put it in. it just splits the 12 volt source.
Ok. More thoughts. I want something with RAP so it stays on with the radio. Just not a constant, like the mirrors.
So what is RAF/MOD?
Can I use the HVAC?
you can use any fuse that dont work when the cars off.
like i said, your adding a new fuse to the fuse slot. its splits the 12 volt source. so the add a fuse now holds two fuses.
you can take a 2 dollar test light and test the fuses for power car off.
Well, the investigation started. All the 10A fuses are hot. The only switched one I could find was the cruise/sw. No problem. Tapped into it and got excited. Started to strip the radio and interior (in the ice cold garage) only to find that the antenna on a GM car is not the same as a standard motorola adapter. Off to Best Buy to get the adapters in the AM.
