Thread: 12v switched from side fuse box
Results 1 to 15 of 15
  1. #1 12v switched from side fuse box
    Akron, Ohio
    I am putting in a transit blu hf. It needs a 12v switched power source. I bought a fuse tap and did this before, but I can't remember which one is switched.
  2. #2 Re: 12v switched from side fuse box
    you mean a off fuse when the cars off? like the wiper fuse? what my amp is hooked to.
  3. #3 Re: 12v switched from side fuse box
    Akron, Ohio
    Yeah. Where is the wiper fuse?
  4. #4 Re: 12v switched from side fuse box
    if you have a cover on the fuse box there should be a map there. i got a regal im sure its not in the same place.
  5. #5 Re: 12v switched from side fuse box
    Akron, Ohio
    These are my choices
  6. #6 Re: 12v switched from side fuse box
    Akron, Ohio
  7. #7 Re: 12v switched from side fuse box
    man Bills right giant piles lol your fuse box blows. use the radio fuse it turns off when the cars off.
  8. #8 Re: 12v switched from side fuse box
    Jul 2010
    Coquitlam,BC,Canada
    What year? Where are all the fuses? LOL
    Here is where I put my two taps (radio and sunroof).....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: 12v switched from side fuse box
    Akron, Ohio
    2006 grand prix gt
    The sunroof is switched? I could use that since I don't have a sun roof.
    Doesn't the radio stay on with the RAP?
    My fuse tap is 2-10 amps. The sunroof is 20, but since there is no sun roof, does it matter?
  10. #10 Re: 12v switched from side fuse box
    sun roof is more then likely blank inside the fuse block.
    when using a add a fuse, your still using your amp fuse with it. as well as the spot your using to put it in. it just splits the 12 volt source.
  11. #11 Re: 12v switched from side fuse box
    Akron, Ohio
    Ok. More thoughts. I want something with RAP so it stays on with the radio. Just not a constant, like the mirrors.
    So what is RAF/MOD?
    Can I use the HVAC?
  12. #12 Re: 12v switched from side fuse box
    you can use any fuse that dont work when the cars off.
    like i said, your adding a new fuse to the fuse slot. its splits the 12 volt source. so the add a fuse now holds two fuses.
    you can take a 2 dollar test light and test the fuses for power car off.
  13. #13 Re: 12v switched from side fuse box
    Akron, Ohio
    Well, the investigation started. All the 10A fuses are hot. The only switched one I could find was the cruise/sw. No problem. Tapped into it and got excited. Started to strip the radio and interior (in the ice cold garage) only to find that the antenna on a GM car is not the same as a standard motorola adapter. Off to Best Buy to get the adapters in the AM.
  14. #14 Re: 12v switched from side fuse box
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by dgjks6 View Post
    Yes.
    Yes.
    No.
    ^ This.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: 12v switched from side fuse box
    Jul 2010
    Coquitlam,BC,Canada
    Your picture above shows 2amp for the cruise circuit. That seems low, but if it is correct, I would stay away from it.
    The radio circuit is a safe choice.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Just switched to E85... Here's what I learned!
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 07-11-2014, 09:07 PM
  2. Passenger side fuse box
    By Stormhaven in forum 04+ Specifics
    Last Post: 06-30-2013, 06:31 PM
  3. switched accessory tap
    By ham4864 in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:21 PM
  4. Switched Ignition Source
    By Blackhawk in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2009, 05:51 PM
  5. 12volt switched source?
    By nyydmb12 in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2009, 06:45 AM
