Thread: DIY Install Remote Start on 2004 Grand Prix GTP Looking for help
Results 1 to 4 of 4
nickolaughagus DIY Install Remote Start on... 01-08-2015, 02:09 PM
industrialfish Re: DIY Install Remote Start... 01-09-2015, 03:58 AM
nickolaughagus Re: DIY Install Remote Start... 01-09-2015, 03:18 PM
REDCRAPGP Re: DIY Install Remote Start... 01-09-2015, 03:41 PM
  1. #1 DIY Install Remote Start on 2004 Grand Prix GTP Looking for help
    Jan 2014
    United States
    Hey guys, yesterday while I nearly froze in my car while I waited for it to heat up, I looked up Remote Starter kits.
    I have decided to purchase and install one myself, while getting the best bang for the buck.
    Right now I'm looking at getting the Viper 5301 Responder used off of Ebay for hopefully around $50, as well as the DEI Bypass module 556uw.
    If you guys know of better systems let me know, but this seems like a pretty good deal.
    The main features I need is lock/unlock/trunk, Heating/AC on, Long range, RPM monitor to re-attempt start if failed the first time, and Heated seat control.
    I have 2 different wiring diagrams right now, but no pictures to accompany them, so if anyone has pictures that'd be good.
    Also, I am not sure if I need any other modules. I am confident in my ability to splice into the system without issue, so I dont think Ill need harnesses if Diagrams are good enough.
    I mainly am looking for tips before I begin this investment.
    Thanks for your time everyone!
    Tired of eternally freezing my balls off,
    Nickolaughagus
  2. #2 Re: DIY Install Remote Start on 2004 Grand Prix GTP Looking for help
    Oct 2011
    Toledo, OH
    Best bang for your buck is to get the factory remote start installed if you can. If you have the RPO code of AP8 you can grab a 05 BCM and key fobs, and have the dealership activate it.
    7"
  3. #3 Re: DIY Install Remote Start on 2004 Grand Prix GTP Looking for help
    Jan 2014
    United States
    Quote Originally Posted by industrialfish View Post
    Where do I check for that code?
    Also does the BCM change between GTP/GT/STANDARD Models? I have a 2004 GTP.
    Finally, It seems like a 5 button keyfob is $50 and a BCM is $40, which is I am assuming just 1-way communication.
    I would probably rather get the Viper 5301 for that price if I can win the bid, Because it is 2-way and it tells you when the car is warmed up enough to get in, with realtime temperature updates.
    Do you know if the factory is 2way?
  4. #4 Re: DIY Install Remote Start on 2004 Grand Prix GTP Looking for help
    Factories not two way
    04 Comp G.
  1. 06 Grand prix remote start
    By kizy3647 in forum Introductions/Noob Questions
    Last Post: 08-31-2021, 08:01 PM
  2. 2007 Pontiac grand prix remote start problems
    By 1lofton in forum General Grand Prix Discussion
    Last Post: 02-02-2013, 01:15 PM
  3. Remote Start Install Questions
    By 1detroitryder in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 08:24 AM
  4. Remote start on a 2008 Grand Prix GXP
    By duelgrandprix in forum Introductions/Noob Questions
    Last Post: 10-07-2011, 02:52 PM
