Thread: Low beams not working .... Again !!
Results 1 to 8 of 8
  1. #1 Low beams not working .... Again !!
    May 2013
    Wilmington
    I have a 2004 GP and the other day I noticed my low beams were not on. It was light when I set off. When I got home I turned the lighs off and display read "headlamps recommended" i turned it to manual again and auto, it's like the car thinks they're on until i turn them off. I did some research and found that it was most likely the relay for The low beams. so I bought a new relay, switched it, tested it and .. Hey presto..the lights were back on.. All good right? Nup, I left work tonight and noticed no lights .. I took the relay out, blew it, checked for debris etc and put it back .. No lights still .. So .. What do you think? ? Any suggestions?
    Thanks all ..
  2. #2 Re: Low beams not working .... Again !!
    Have you replaced the HDM module yet?
  3. #3 Re: Low beams not working .... Again !!
    May 2013
    Wilmington
    No, I will research that, if you had any links that would be appreciated.
  4. #4 Re: Low beams not working .... Again !!
    Enfield, CT
    It's number 35 in the under hood fuse box. Its your fix
  5. #5 Re: Low beams not working .... Again !!
    May 2013
    Wilmington
    Quote Originally Posted by HighOctaneRacing View Post
    That's the part I changed yesterday. It seemed to be the fix but today it's back to no lights.
  6. #6 Re: Low beams not working .... Again !!
    Was it a 4 pin relay or a 5 pin relay?
    The HDM module is a 5 pin.
  7. #7 Re: Low beams not working .... Again !!
    May 2013
    Wilmington
    the one I took out was a 4 pin. I just took that to the store and they gave me the same thing. Although it does say made in China, could it be crappy? The 4 pin's been in all the 5 years I've had the car with no issues until recently.
  8. #8 Re: Low beams not working .... Again !!
    May 2013
    Wilmington
    Ok so I think I have fixed my low beam issues. I tried another relay.. no good. I decided to pull the high beam relay and put it where the low beam relay was .. its exactly the same relay.. still no low beam .. for s**ts and giggles I tried my original relay for the high beams .. it worked !! So I changed both low beam bulbs .. and now .. I have light !!!Woohoo .... i'm not convinced something else isn't going on though as the relay switch worked the first time .. maybe I had a loose wire somewhere .. I dunno but i'll keep an eye on it and post back if I find another issue . .fingers crossed i'm scratching this off as solved .. new bulbs . .what an idiot I feel !!
  1. High beams not working
    By cbehrenwald1988 in forum General Grand Prix Discussion
    Last Post: 02-18-2014, 02:58 PM
  2. Low beams not working
    By SpringfieldGT in forum General Grand Prix Discussion
    Last Post: 09-26-2013, 09:30 AM
  3. HELP!! Low beams not working
    By 2coolit in forum Visual/Body Modifications
    Last Post: 05-22-2013, 10:32 AM
  4. Low beams not working.
    By Focusin in forum General Tech Discussion
    Last Post: 04-24-2013, 12:07 PM
  5. My DRLs & Low Beams Are not working, high beam work
    By FlaminWhite97GTP in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2010, 01:26 PM
