Thread: Subwoofer wiring Questions..
Results 1 to 9 of 9
Preston Subwoofer wiring Questions.. 12-26-2008, 10:17 PM
reinke Re: Subwoofer wiring... 12-26-2008, 11:46 PM
reinke Re: Subwoofer wiring... 12-26-2008, 11:47 PM
Toofastgs Re: Subwoofer wiring... 12-27-2008, 03:07 AM
Preston Re: Subwoofer wiring... 12-27-2008, 07:23 PM
reinke Re: Subwoofer wiring... 12-27-2008, 08:57 PM
Preston Re: Subwoofer wiring... 12-29-2008, 12:28 AM
GeddyLee Re: Subwoofer wiring... 01-03-2009, 03:14 PM
reinke Re: Subwoofer wiring... 12-31-2008, 02:26 PM
  1. #1 Subwoofer wiring Questions..
    Jul 2008
    ok so im getting this...
    2 kenwood KFC-W3514DVC subwoofers
    1 kenwood KAC-8104D amp
    my questions are..
    whats the best way to wire these subs to this amp?
    the amp has 2 sets of speaker terminals (+,+,-,-) so do i just wire the subs in a series and put the speaker wires in one set of terminals since the amp is not bridgeable?
    and if i wire the subs together in a series, do i wire them inside the box then just have on set of wires coming out?
  2. #2 Re: Subwoofer wiring Questions..
    GT Level Member reinke's Avatar
    Oct 2008
    cleveland, ohio
  3. #3 Re: Subwoofer wiring Questions..
    Oct 2008
    cleveland, ohio
  4. #4 Re: Subwoofer wiring Questions..
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Well you are only going to get a 4ohm load out of that set up and that is 300watts RMS 1k watt is a joke. Maybe for a split second in a musical peak but that will only happen on a 2ohm load.
    But you will wire + to + then + to + so all + are connected to one + output on amp Same thing with -
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  5. #5 Re: Subwoofer wiring Questions..
    Jul 2008
    ok, new question... im getting a different amp that is 1 ohm stable (600watt x 1 channel)
    ifi wire it like this diagram.. how would i connect the wire from the left sub to the right sub?
    http://www.rockfordfosgate.com/rftec...hmDVC_1ohm.gif
  6. #6 Re: Subwoofer wiring Questions..
    Oct 2008
    cleveland, ohio
    it can not be explained more clearly than what is in the diagram you posted man.
  7. #7 Re: Subwoofer wiring Questions..
    Jul 2008
    how would i connect it at those red dots i made?
    or could i re-route the wire to how i drew the red ones in?
  8. #8 Re: Subwoofer wiring Questions..
    St. Louis Mo.
    Quote Originally Posted by Preston View Post
    You can run the wire like you have, but its better to tap the one line into the other like the diagram shows. Its not hard to tap the wiring and add in another length of wire to complete the diagram. Just use some sauter and electrical tape to seal off the tap and you are good to go.
    James Shafer
    St. Louis MO
  9. #9 Re: Subwoofer wiring Questions..
    Oct 2008
    cleveland, ohio
    the line that looks like a pencil drew it is how the woofers are connected together. just look at the pic and it will become clearer.
  1. questions about the monsoon wiring..
    By blowfishRus6 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 06:42 PM
  2. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
  3. Wiring questions for you electronic guys out there...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 06-14-2008, 05:19 PM
