Thread: Running power wire
Results 1 to 17 of 17
  1. #1 Running power wire
    Dec 2013
    pulaski
    On the 98 GTP is there anywhere I can go through the fire wall with 0 gauge wire without drilling?
  2. #2 Re: Running power wire
    Florida
    You should be able to get it through the firewall. Theres a rubber grommet/plug directly behind the alternator, about a foot down or so. Pull that plug out, and jam the wire in there. You'll have to fish around under the passenger side dash, under the carpet for a bit to get it pulled through.
  3. #3 Re: Running power wire
    Florida
    Picture of said area
    Obviously that's a much smaller gauge wire, but if you remove that entire rubber plug, you should have room
  4. #4 Re: Running power wire
    Dec 2013
    pulaski
    Nice, thanks man. I knew I didn't have a drill handy where I am and I didn't even look but that plug comes right out.
    Edit: Now I'm having trouble fishing.
  5. #5 Re: Running power wire
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    Did u ever end up getting the 0ga threw? Once u got threw where did u run it? I'm putting a killer system in and need to run 0ga as well.
  6. #6 Re: Running power wire
    dust.. pull pass carpet back at firewall
    You'll see the main wiring feed. Go there
  7. #7 Re: Running power wire
    Mar 2014
    Canada
    Thanks for the reply bill, but what I meant was, where do I run the 0ga threw the interior to the trunk? The smaller 4ga I have for my system now fots one under the trim Along the bottom of the doors. Just don't think 0ga will work in there?
  8. #8 Re: Running power wire
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Run it under the carpet, just remove the passanger seat if you need then pull the back seats and pull the carpet back should find some place
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: Running power wire
    Quote Originally Posted by Dustoff View Post
    i drilled a hole under the wind shield took the cowl off and drilled a hole, fed the wire in the hole it came out to the floor like nothing.
    then took the door sills off, the carpet has a few loops over hooks, take them off, tuck the wires down the side of the carpet.
    i ran my remote power wire to the amp with the power cable from the dash along the sides and took the back seat out to get the wires to the trunk.
    if your running rca cables you may want to pull the pass front seat and run the cables closer to the middle console and up to the radio. you can go the long way if they reach of course.
  10. #10 Re: Running power wire
    Mar 2014
    Canada
    Perfect. I'll prob end up going under the cowl as that seems to be the easiest way and safe as long as I avoid the drainage. Thanks for the input, much appreciated. Now the wait for my new DC level 4!!
  11. #11 Re: Running power wire
    in this pic, on the left side you see a piece of metal dividing under the windshield. i made my hole to the left of that metal.. maby a inch over and as high up as i could. i needed a long drill bit to get in there too.
    the red wire leading under the corner of the cowl is the amp power cable.
  12. #12 Re: Running power wire
    I'm confused. You said to me that you wanted to go into the trunk and that you had previously run under the trim. Scotty says make a hole in the firewall and you say perfect. If that's perfect..then you could also consider what I suggested.
  13. #13 Re: Running power wire
    Apr 2012
    Dayton, OH
    If thats the grommet in the pass floor board thats what I used easiest way ever plus it will seal itself when you pull the wire through. Just cut the hold too small
    2012 F150 STX
  14. #14 Re: Running power wire
    Dec 2013
    pulaski
    This is how I was able to do it. I didn't go under the carpet with the wire until I was at the back of the center console.
    http://youtu.be/__dlX_hywjo
  15. #15 Re: Running power wire
    that rubber block in the floor, well it scares me lol its a tight spot under the car, and all them wires. that is why i made my own hole to get in.
  16. #16 Re: Running power wire
    Bet you are scared of spiders too...aren'tcha?
  17. #17 Re: Running power wire
    nope. i let them live if i see them on the ceiling. they eat other worse bugs.
    if they are somewhere i dont want them, they die lol
  1. Running Speaker Wire
    By Lowdown112 in forum Audio, Security & Visual Electronics
    Last Post: 01-07-2013, 04:30 AM
  2. Running a power wire
    By Leroyy in forum 04+ Specifics
    Last Post: 08-14-2012, 04:15 PM
  3. running amp power wire question
    By bps02gtp in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2012, 12:21 AM
  4. Running amp power wire
    By c40verload in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2011, 01:26 PM
  5. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
