Thread: running amp power wire question
Results 1 to 10 of 10
bps02gtp running amp power wire... 07-13-2011, 02:02 AM
rynoman03 Re: running amp power wire... 07-13-2011, 02:09 AM
BillBoost37 Re: running amp power wire... 07-13-2011, 05:30 AM
bps02gtp Re: running amp power wire... 07-13-2011, 03:36 PM
JWillas92 Re: running amp power wire... 07-15-2011, 04:59 PM
machinegunsquid Re: running amp power wire... 07-15-2011, 05:39 PM
ZachG Re: running amp power wire... 05-27-2012, 09:11 PM
develand Re: running amp power wire... 05-28-2012, 11:46 AM
ZachG Re: running amp power wire... 05-28-2012, 12:54 PM
bps02gtp Re: running amp power wire... 05-29-2012, 12:21 AM
  1. #1 running amp power wire question
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Right now I'm working on mechanical projects on my gp and haven't had time to look at how I wanna run my power cable for my amp. I see its gonna be on the passenger side. And I see its gonna be kinda low and a little in towards the middle of the firewall because of the strut tower. So what did u guys do? Did u drill a hole? Where'd u put it? Lemme know. Thanks
  2. #2 Re: running amp power wire question
    Topeka, KS
    There's a rubber plug you can run all sorts of stuff threw on the passengers side behind the carpet\kick plate near the middle torward the firewall you'll see wires going to it. You gotta pull the plug out but its water tight until you poke a hole threw it to run things.
  3. #3 Re: running amp power wire question
    Here's what the Rhino is talking about.
  4. #4 Re: running amp power wire question
    Nov 2010
    Illinois
    ah ok. ive seen that before. awesome thanks guys. those pics are awesome and very helpful. my power wire is the next step up tho and so its a little thicker. 4 guage i believe? but it should still work right?
  5. #5 Re: running amp power wire question
    Jun 2011
    Chicago
    should I just poke a hole through the rubber seal thing using a drill bit or a screw driver? And when you poke the whole through it, it will no longer be water tight. Could that cause any major problems if its not water tight?
  6. #6 Re: running amp power wire question
    Florida
    I literally took the big plug, pulled it out, and cut it off of the cable/wires going in. Never had a single problem with water. (comming from someone who lives in FL, who constantly has over 6" of standing water in their driveway/roads)
    You can use a screwdriver, then bore it out with a drill bit, just be careful.
    And it looks like 4ga wire in that pic, but it might be 5....
    I ran 4ga through that hole, powering a 2000watt amp, to a 15, and the 4ga was plenty.
  7. #7 Re: running amp power wire question
    Apr 2012
    Manorville, Ny
    Hey I just ran my 1/0 threw that square grommet today, I removed the plug then poked my wire threw then put the plug back in as best as I could, I haven't driven the car yet & I want to know how any of you guys re-sealed the hole better. Should I put silicone threw there cause I don't want rain or water coming into my car.
  8. #8 Re: running amp power wire question
    GTP Level Member
    Nov 2011
    Kansas
    I attached my wire to a metal coat hanger and taped the wire to that and pushed it through next to the existing wire.
  9. #9 Re: running amp power wire question
    Apr 2012
    Manorville, Ny
    Well I'm going hmto have to say my wire im useing is the same size as the preexisting wires its 0 gauge so I had to go on the side of the boot bot through but I worry that water may come inside so I'm asking how to better seal the hole without taking it out.
    1998 Grand Prix Gtp 4 Door.
    Team Li SPL
  10. #10 Re: running amp power wire question
    Nov 2010
    Illinois
    It poked it thru and it was reallly tight and hard. (That's what she said) so I wasn't worried about water and 1 year later I'm still good. If u wanna silicone around it it won't hurt. It'll just be a pain in the butt to get the wire out if u ever want to.
  1. power wire question?
    By Dragonblaze in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2010, 01:23 PM
  2. Amp power wire help!!!!!
    By Goldoni in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 08:00 AM
  3. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  4. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
  5. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
