Thanks for the reply bill, but what I meant was, where do I run the 0ga threw the interior to the trunk? The smaller 4ga I have for my system now fots one under the trim Along the bottom of the doors. Just don't think 0ga will work in there?
i drilled a hole under the wind shield took the cowl off and drilled a hole, fed the wire in the hole it came out to the floor like nothing.
then took the door sills off, the carpet has a few loops over hooks, take them off, tuck the wires down the side of the carpet.
i ran my remote power wire to the amp with the power cable from the dash along the sides and took the back seat out to get the wires to the trunk.
if your running rca cables you may want to pull the pass front seat and run the cables closer to the middle console and up to the radio. you can go the long way if they reach of course.
