I just bought some new speakers and im wondering if I have to cut the plug from the stock ones to wire in the new ones. I wired my deck up by myself and have a sub and amp ready to put in as well.
and your system is suffering from just tape, the wire ends are exposed to air will turn tarnished and fail to flow signal properly over time. it may take a year or more to happen, but it will.
a cheap soldering kits is like under 20 bucks, so many uses in the future too. i got mine at HF, 3 bucks for the iron, 3 bucks for shrink tubes, and i got flux core solder at radio shack for 5 bucks. done deal. used it so many times now its paid for its self over and over.
Ditto^ Please solder the connections. It may work without it, but you're sacrificing some of what little wattage the head unit puts out. 22 watts at most, so you really want all of it.
Wow guys thanks! Fast response. How will I keep the stock tweeters working?
You wouldnt recommend going out and getting the adapters scotty?
Thanks guys got those Pioneers in and it sounds great. It was SO simple. My buddy was impressed I wired the harness for the head unit and the speakersi have a 1500w kenwood amp and a jbl or whatever the conpany is competition sub. Should I amplify rear speakers and sub?
I never really figure out the reasoning behind the adapters for the speakers, most people just toss out their old speakers anyway. The stereo on the other hand the adapters make sense. Most people add in an aftermarket stereo and keep the stock deck in their garage/attic/closet then when they want to sell the car they put the stock head unit back in. Nothing is more annoying than trying to figure out what wires are for what when someone hacks up the stock harness.
I just unsoldered the plug from the stock speakers and soldered it to my replacements.
dont cut the plugs, just expose a little bit of the wire, about an inch from the plugs this way if you ever want to put the old speakers back in, you can.
Cut em. Tossed em. Got bomb pioneers in there now! Next....the rear speakers!
Even more fun because you get to remove the rear seats.
Sent from my Galaxy Tab 3 8.0
i can get the back seats out in like 10 minutes. add another 5 for the rear dash cover over the speakers.
faster then the front doors, or the front seats for sure.
Wut. it takes like 2 minutes to get each front door panel off. Some of the bolts in the back seat are torqued way too tight from the factory
its 2 bolts and 2 nuts tops. came right the f out. the thread sealer takes some force to get moving but they come out.
good time to clean your seat belts if they are dirty too.
