Thread: 04 GP front speakers! Do I cut the plugs?
Results 1 to 20 of 24
  1. #1 04 GP front speakers! Do I cut the plugs?
    Apr 2014
    Ontario
    I just bought some new speakers and im wondering if I have to cut the plug from the stock ones to wire in the new ones. I wired my deck up by myself and have a sub and amp ready to put in as well.
  2. #2 Re: 04 GP front speakers! Do I cut the plugs?
    yes you will have to clip the stock plug ends off to use the new speakers.
    best to solder and shrink tube the connections.
  3. #3 Re: 04 GP front speakers! Do I cut the plugs?
    Aug 2013
    McDonald PA
    Never had electrical tape and wrap the wire around eachother a few times fail me. I've done 5 or 6 sets like yhat
  4. #4 Re: 04 GP front speakers! Do I cut the plugs?
    and your system is suffering from just tape, the wire ends are exposed to air will turn tarnished and fail to flow signal properly over time. it may take a year or more to happen, but it will.
    a cheap soldering kits is like under 20 bucks, so many uses in the future too. i got mine at HF, 3 bucks for the iron, 3 bucks for shrink tubes, and i got flux core solder at radio shack for 5 bucks. done deal. used it so many times now its paid for its self over and over.
  5. #5 Re: 04 GP front speakers! Do I cut the plugs?
    Pennsylvania, USA
    Ditto^ Please solder the connections. It may work without it, but you're sacrificing some of what little wattage the head unit puts out. 22 watts at most, so you really want all of it.
  6. #6 Re: 04 GP front speakers! Do I cut the plugs?
    Apr 2014
    Ontario
    Wow guys thanks! Fast response. How will I keep the stock tweeters working?
  7. #7 Re: 04 GP front speakers! Do I cut the plugs?
    mine were split off the front speakers. so you can cut and solder them back in line.
  8. #8 Re: 04 GP front speakers! Do I cut the plugs?
    Apr 2014
    Ontario
    You wouldnt recommend going out and getting the adapters scotty?
  9. #9 Re: 04 GP front speakers! Do I cut the plugs?
    never saw then for sale, being the cheap ass i am, ive always just cut the factory pugs off, and soldered on the new plugs that come with the new speakers.
  10. #10 Re: 04 GP front speakers! Do I cut the plugs?
    Apr 2014
    Ontario
    Thanks guys got those Pioneers in and it sounds great. It was SO simple. My buddy was impressed I wired the harness for the head unit and the speakers i have a 1500w kenwood amp and a jbl or whatever the conpany is competition sub. Should I amplify rear speakers and sub?
  11. #11 Re: 04 GP front speakers! Do I cut the plugs?
    I never really figure out the reasoning behind the adapters for the speakers, most people just toss out their old speakers anyway. The stereo on the other hand the adapters make sense. Most people add in an aftermarket stereo and keep the stock deck in their garage/attic/closet then when they want to sell the car they put the stock head unit back in. Nothing is more annoying than trying to figure out what wires are for what when someone hacks up the stock harness.
  12. #12 Re: 04 GP front speakers! Do I cut the plugs?
    Oct 2011
    Toledo, OH
    I just unsoldered the plug from the stock speakers and soldered it to my replacements.
    7"
  13. #13 Re: 04 GP front speakers! Do I cut the plugs?
    May 2014
    Pittsburgh
    dont cut the plugs, just expose a little bit of the wire, about an inch from the plugs this way if you ever want to put the old speakers back in, you can.
  14. #14 Re: 04 GP front speakers! Do I cut the plugs?
    who you kidding? the stock speakers are blown, sound like crap when compared to new speakers and the old speakers are never going back in. cut and toss the plugs.
  15. #15 Re: 04 GP front speakers! Do I cut the plugs?
    Apr 2014
    Ontario
    Cut em. Tossed em. Got bomb pioneers in there now! Next....the rear speakers!
  16. #16 Re: 04 GP front speakers! Do I cut the plugs?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Even more fun because you get to remove the rear seats.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  17. #17 Re: 04 GP front speakers! Do I cut the plugs?
    i can get the back seats out in like 10 minutes. add another 5 for the rear dash cover over the speakers.
    faster then the front doors, or the front seats for sure.
  18. #18 Re: 04 GP front speakers! Do I cut the plugs?
    Indianapolis
    Wut. it takes like 2 minutes to get each front door panel off. Some of the bolts in the back seat are torqued way too tight from the factory
    2004 GT N/A: 343whp/240wtq, L26, HV3, headers, intake, shifting at 9k rpm, stock bottom end, tuned by me
  19. #19 Re: 04 GP front speakers! Do I cut the plugs?
    its 2 bolts and 2 nuts tops. came right the f out. the thread sealer takes some force to get moving but they come out.
    good time to clean your seat belts if they are dirty too.
  20. #20 Re: 04 GP front speakers! Do I cut the plugs?
    Enfield, CT
    never had electrical tape and wrap the wire around eachother a few times fail me. I've done 5 or 6 sets like yhat
    fail!
    and your system is suffering from just tape, the wire ends are exposed to air will turn tarnished and fail to flow signal properly over time. It may take a year or more to happen, but it will.
    A cheap soldering kits is like under 20 bucks, so many uses in the future too. I got mine at hf, 3 bucks for the iron, 3 bucks for shrink tubes, and i got flux core solder at radio shack for 5 bucks. Done deal. Used it so many times now its paid for its self over and over.
    win!
  1. front speakers
    By jhintz in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2013, 02:01 PM
  2. pioneer ts G1642R speakers into front doors speakers?
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 10:16 AM
  3. Front speakers
    By Edagimo in forum Audio, Security & Visual Electronics
    Last Post: 12-14-2010, 04:20 AM
  4. front speakers
    By dengnath in forum Audio, Security & Visual Electronics
    Last Post: 10-30-2010, 06:53 PM
  5. front speakers
    By flipzat in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 12:34 PM
