Are you using same ground for both amps? If so then I understand the problem affecting both. However if not then only one amp would be effected by each separate ground. Either way my money is on the power supply is the part that sucks not the grounds. When on ACC the power fades in and out because its on battery power not altenator power from the vehicle. Id start by checking the altenator and battery.
