Thread: Price check
Results 1 to 13 of 13
  1. #1 Price check
    Mar 2014
    Indiana
    Are 2 12" alpines plus a 600 amp worth 80$? Also how hard is it to install?
    2002 Fully Loaded GTP. Cat back exhaust and 20% window tint all the way around(Rollin in the dark). Soon to be CAI, headers, and high flow cat.
  2. #2 Re: Price check
    Florida
    If they are in good shape, hell yes.
    What brand/model is the amp?
    If you've never installed an amp/sub before, it's hard. Once you know what you're doing, it's easy peasy
  3. #3 Re: Price check
    i wired up a sub and amp, never did it before. found it rather easy, its just running power lines and stuff.
  4. #4 Re: Price check
    Mar 2014
    Indiana
    Comes with box but no wires
  5. #5 Re: Price check
    Mar 2014
    Indiana
    Sorry it's a pyramid amp
  6. #6 Re: Price check
    amp install kits start around 20 bucks. for cheap ones. of course it goes up from there.
    most come with rca cables, remote wire, and power lead with a inline fuse and a ground cable.
  7. #7 Re: Price check
    Mar 2014
    Indiana
    Or since I have the Bose system will I be ok just swapping speakers
  8. #8 Re: Price check
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I really wouldn't skimp out on the power/ground wires imo. Get good quality wire. KnuKoncepts I think is the name has really good amp kits with quality wire and fuses I got a 4ga kit with power, ground, RCAs, fuse, terminals for under 50 I think, and its nice and beefy while really flexible. Overkill for 500w rms but left room for upgrades.
    Sent from my Galaxy Tab 3
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: Price check
    Mar 2014
    Indiana
    Yeah this one has absolutely 0 wiring. I'm thinking just replacing the door ones would be up my alley but would I still have to buy an amp?
  10. #10 Re: Price check
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by GTPgasm View Post
    If you're expecting bass from those 12 inchers, yes. You will need an amp.
    See if you can go online and find an installation manual for the amp you're looking at. It'll tell you what size power cables you'll need to feed the amp. If it's a 600 amp max output total, you'll need either 8 gauge or 10 guage wire. If it's 600 amps per channel RMS, you're into 4 guage or larger territory. Regardless, get good connectors and make sure your amp's wiring has a separate fuse.
  11. #11 Re: Price check
    not sure how you would go about dealing with a bose. if its got a amp already it may be a issue. if not. you could just use it as a sub and amp. and leave the stock system alone. you use a line level off the rear speaker to the amp.
  12. #12 Re: Price check
    Feb 2014
    Grand Forks, North Dakota
    Pyramid is not the greatest brand for car audio from what I've read, because of longevity and incorrect numbers/wattage they say their products can handle and put out. But that price for two alpine subs is pretty good depending on the condition they are in and the amp is just a bonus! What model are the subs, type E S R X?
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  13. #13 Re: Price check
    Dec 2013
    United States
    I got a 12 inch alpine type x with a box and alpine 1200 watt amp in one of my grand Prixs its loud for just one sub...
    Sent from my XT1055 using Tapatalk
  1. Replies: 99
    Last Post: 12-23-2014, 02:22 PM
  2. Reasonable Price?
    By tdm571 in forum The Rant Forum
    Last Post: 05-19-2011, 07:40 PM
  3. Price of Top Swap?
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2008, 07:15 PM
