Thread: 2 amps...1 problem!!
Results 1 to 13 of 13
  1. #1 2 amps...1 problem!!
    Jersey
    I have a Eclipse XA4200 powering two tweeters (Polk) and two coaxials (Alpine). I also have a Alpine MRV T757 powering two Sony 12s. Recently the highs amp has been shutting off and on while driving. Bass amp stays on and playing (not kool). Now if i turn the car to acc mode...it sounds like the music fades in and out. What could be the problem? Grounds to both amps are fine and are connected at one point. I do have a melted fuse block under the hood that will get fixed, but i dont think that's the issue. Thanks. If you need pics let me know
  2. #2 Re: 2 amps...1 problem!!
    Where did you ground the amp at?
    04 Comp G.
  3. #3 Re: 2 amps...1 problem!!
    Jersey
    The metal part that supports the back seats
  4. #4 Re: 2 amps...1 problem!!
    Jersey
    <a href="http://s792.photobucket.com/user/AndrewOliver2013/media/67F54C4D-4C2A-4242-9CAA-7F9287C13E19_zpsxp92cxab.jpg.html" target="_blank"><img src="http://i792.photobucket.com/albums/yy207/AndrewOliver2013/67F54C4D-4C2A-4242-9CAA-7F9287C13E19_zpsxp92cxab.jpg" border="0" alt=" photo 67F54C4D-4C2A-4242-9CAA-7F9287C13E19_zpsxp92cxab.jpg"/></a>
  5. #5 Re: 2 amps...1 problem!!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Pic fail
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: 2 amps...1 problem!!
    Jersey
  7. #7 Re: 2 amps...1 problem!!
    Try moving your ground.. Try the bolt underneath the seatbelt bracket.
    04 Comp G.
  8. #8 Re: 2 amps...1 problem!!
    Apr 2012
    Dayton, OH
    I use the strut tower bolt. Could be possible the amp could be damaged or dying.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
  9. #9 Re: 2 amps...1 problem!!
    SE Level Member GrandPrixMI's Avatar
    Mar 2014
    SouthWest Michigan
    Is it in protected mode when it shuts on and off? I have my ground behind the backseat under the carpet along a metal bar. That's me though.
    2000 Grand Prix GT Coupe - 2 12" Kickers 2000W Hifonics Amp, K&N CAI, 155k Miles
  10. #10 Re: 2 amps...1 problem!!
    Are you using same ground for both amps? If so then I understand the problem affecting both. However if not then only one amp would be effected by each separate ground. Either way my money is on the power supply is the part that sucks not the grounds. When on ACC the power fades in and out because its on battery power not altenator power from the vehicle. Id start by checking the altenator and battery.
  11. #11 Re: 2 amps...1 problem!!
    Feb 2014
    Grand Forks, North Dakota
    What 98GrandPrixIraqVet said. When you have the two grounds fastened in the same spot, one of the amps is probably grounding out into the other. For power, your drawing to much.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  12. #12 Re: 2 amps...1 problem!!
    Jersey
    I'll try to seperate the grounds when i get the chance. And this amp doesnt indicate when it goes into protection mode
  13. #13 Re: 2 amps...1 problem!!
    Jersey
    UPDATE!!! The screw i use to connect the grounds wasn't fully tight. I added a flat washer and everything is fine...thanks guys
  1. 1 or 2 AMPs any suggestions???
    By Dee23 in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2012, 11:50 AM
  2. How are your amps mounted?
    By archemedes in forum Audio, Security & Visual Electronics
    Last Post: 10-10-2009, 08:49 PM
  3. Amps?
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2009, 12:01 PM
  4. subs and amps
    By edp in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2008, 04:22 AM
